Thread: Standard Drive Belt Size ?
	17-05-2009 #1
Hi
Is there a standard set of drive belt size’s we should really be designing to or ?
Is it standard belts your after for drive pullys then look at this
http://www.hpcgears.com/calc.htm
just put in the gears you are using and the space between them and it gives you the belt req
but you may be talking about something else.
Peter
	19-05-2009 #3
I've been using aluminium Imperial XL pulleys from RS who are actually quite reasonable priced, kind of freaky for RS to be reasonably priced but there you go.
Many years ago we were writing software for a LARGE Russian XY table, only a vague recollection, lots of water under the bridge since then etc., but the bit I do remember was that it positioned using spring steel bands around rollers. Seemed a lot more practical than toothed belt and stuck in my mind.
idea for linear belt drive
By dickieto in forum Rails, Guideways & BearingsReplies: 36Last Post: 28-02-2021, 05:33 PM -
Belt drive on a router
By John S in forum Rails, Guideways & BearingsReplies: 23Last Post: 10-09-2012, 09:39 PM -
any one know where to get a belt drive convertion for x2
By Scott in forum Sieg Milling MachinesReplies: 15Last Post: 27-09-2010, 08:44 PM -
Toothed belt size selection help.
By cweeks in forum Belt Drive, Pulleys & TimingReplies: 0Last Post: 20-09-2010, 11:53 PM -
Re: Standard Drive Belt Size ?
By HS93 in forum Belt Drive, Pulleys & TimingReplies: 0Last Post: 18-05-2009, 03:30 PM
