Thread: On going chinese 6040 problems
07-09-2014 #5
It looks like you have this setup;
3163B Stepper Driver
set to;
Dynamic Current = 2.5A
1/8 Microstep
50% Standstill Current
57HD5401-14S/8 Stepper Motor
1.8 step angle
6.6V
3A
2.2 Ohms
8mH
17kg/cm
4 wire
24v 8.3A DC PSU
1605 ball screws
And that being so, the settings you have seem to be okay as far as I can make out.
However I did a conversion of the motor torque setting and 17 kg/cm = 1.6671305 Nm, this is not so good but as your video shows they are not under load.
I think you could reduce the microstepping and see if that helps, remember to change the Mach3 'steps per' to match.
5m pitch
1.8 deg motor
1/8 microstep (8)
360/1.8 = 200
200/5 = 40
8 * 40 = 320 steps per
Reduce microstepping to 2 by setting K1 ON, K2 OFF
5m pitch
1.8 deg motor
1/2 microstep (2)
360/1.8 = 200
200/5 = 40
2 * 40 = 80 steps perLast edited by EddyCurrent; 07-09-2014 at 10:13 PM.
The Following User Says Thank You to EddyCurrent For This Useful Post:
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Chinese 6040 from uk eBay seller x axis problem
By CommanderKenyon in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 20-02-2015, 02:13 AM -
my 6040 experience (yeah, and problems) so far
By jimbo_cnc in forum Machine DiscussionReplies: 52Last Post: 07-10-2014, 11:26 AM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM
