Thread: On going chinese 6040 problems
The problem with these motors in the inductance is far too high. Check these out:- http://cnc4you.co.uk/resources/60BYGH301B.PDF and see the difference, the motors you have require a much higher voltage to drive them. I would be selling them and getting some with lower inductance. ..Clive
08-09-2014 #2
Now you have lost me with inductance. i got this kit awile ago with the plane to make my own cnc but ended up buying one . this is the kit i have spare
http://www.aliexpress.com/snapshot/6104230003.html
but i was thinking i could just use the stepper motors if the ones im using arnt up to it. So is this not the case ?
Are you saying my power supply is not upto the job because if thats so could i not just swap it out for the 36v one i have ?Last edited by amxen; 08-09-2014 at 09:46 AM.
08-09-2014 #3
On the picture I looked at it says on the terminals 24V, Gnd, so are you sure it can be powered by 36V ? if it can then it might be a good idea to try the other supply.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Chinese 6040 from uk eBay seller x axis problem
By CommanderKenyon in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 20-02-2015, 02:13 AM -
my 6040 experience (yeah, and problems) so far
By jimbo_cnc in forum Machine DiscussionReplies: 52Last Post: 07-10-2014, 11:26 AM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM
