    Is it how many steps it takes the stepper to do 1 revolution of the spindle?
    Quote Originally Posted by amxen View Post
    It would be with a 1 to 1 relationship but if you had pulleys for example with different diameters, then the ratio of those diameters would come into the equation.
    yes it looks like the board has setting of 16.8.2.1 so ill try it set to 2 see if that helps. ill let you know. iv told the seller im not happy with and i would like him to exchange the controller for something thats proven to work or i will open a paypal dispute. i will let you know how i get on
    ok here are my findings for today. I changed the switch settings to 2 in the mico stepping (K1 n K2) and the steps per to 80. The motor runs smooth when not attached to the cnc (good i thought sorted ). But as soon as i attach it back to the cnc the motor jams more than before. It has no torque at all i can put my hand on it and it jams. it has not got the power to traverse the axis. i put it back to how it was.
    So my thoughts are that the steppers motors are under powered.
    But the question
    1 will the stepper motors take more power
    2 will this board give them more power
    3 do i need to replace just the board,? should i get a new all in one board or use the drivers i have from the other kit and just get a BOB that will run these drivers,
    4 will the stepper motors from the other kit i have be ok for me to use ?
    so many questions
    thanks for all the help btw
    Wait, give this a go first, if the velocity / accel in Mach3 is set too high the motor will stall, put the setting back to 2, fit the motor to the machine and reduce the velocity and acceleration until you get good torque.
    Even though you reduced the velocity it could well be faster than previous.
    Here's a quote from another forum;
    "The other day I did switch from 1/10th step to 1/2 step. Seems to operate about the same overall - only MUCH faster. That first rapid move at 180 ipm was a bit shocking. I ended up at 108 ipm - the motors quit stalling then. Probably had to do with the 20 tpi lead screws. The mill runs great! I was slotting ).050" deep with a 3/16 end mill in aluminum at at 18 ipm and the machine seemed happy as can be. And a 0.015" climb cut finish pass left an awesome surface finish. Fun stuff!"
  6. The Following User Says Thank You to EddyCurrent For This Useful Post:
  7. #6
    ok just been down the the cave to try again. I have set things like this K1 n K2 set back to 2 again. i set the setting to
    steps per = 80
    velocity = 1400
    acceleration = 150
    The Torque is a lot better set like this . I can run with out stalling and it seems faster than before.
    I haven't cut anything yet with it like this but i tried to stall the motor by hand and i can but it takes a lot of force to do so.
    what is the difference between velocity and acceleration ?
    Any way it seems we are getting some where. I will try cutting something tomorrow and see how we get on.
    In the long term i think upgrade is in order at some point.
    I would like to say thanks for sticking with me on this. I seem to be learning so much so fast. I should be used to that being a heating engineer . All the help has been much appreciated
  8. #7
    Velocity is just the maximum speed your machine can work at, acceleration is the rate of change from one speed to another, just like your car really.
    Also there is this from the Mach3 documentation;
    "If you can’t seem to get the motors to run smoothly there are a few things to check, first the easy one: Some motor drives need to have a longer step pulse and this can be set by changing the Step Pulse setting. "
    I've tried a few values here for my own machine but found no difference I could detect but I'm using digital drivers, it might though make a difference on your machine.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  4. my 6040 experience (yeah, and problems) so far
    By jimbo_cnc in forum Machine Discussion
    Last Post: 07-10-2014, 11:26 AM
  5. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
