    Hi all and I've stumbled upon this forum a month ago while I was looking at the possibility of purchasing a cnc machine,I eventually did and bought a cnc 3040t which a lot of forum members have done,im mainly interested in milling wood as I would occasionally get a commission to build a wooden static model aircraft which used to take 3 weeks by hand! But mainly I want to learn a new skill over the winter and broaden my hobby engineering skills.
    Owen.
    Welcome Owen, with regard to these models, obviously balsa wood is the stuff for flying models but what kind of wood do you use for the static models ? and what thickness ?
    Also does your machine do the job adequately ?
    Hi eddycurrent
    I usually make my models with whitewood pretty cheap wood you can find anywhere,I want to make more intricate stuff with more detail,also I want to learn a new skill this winter so im excited about getting the machineClick image for larger version.
ID:	13364it Will be a learning experience !here's a Pitts special I hand built for my son Darragh last Christmas:-)
    Nice little plane, have you thought about you are going to cut the parts on cnc ?
    Dunno,I obviously need to do symmetrical wing sections and elliptical fuselage etc,so thats where you guys come in,is it possible on a cnc machine?
    Quote Originally Posted by owen3371 View Post
    Well your machine will likely have X,Y,Z axes, so it's a 2D and 2.5D machine. 2D can be thought of as cutting shapes out a sheet of material, specifically the outlines in the X,Y axes.
    2.5D is using the Z to cut curves, pockets, etc. it's not true 3D becasue it can't undercut. To make a statue for example with undercuts you would need a 4th axis that rotates the work, having said that, it is possible to rotate the work by hand provided you have used a 3D model in your CAD software and calculated each toolpath in your CAM software as the model has been rotated.
    So taking your fuselage, you would lay it on it's side and do 2.5D cutting up to the halfway point, then turn it over and cut the other side, basically like joining two halves of an Airfix fuselage.
    So yes it's possible to make the plane with your machine if you think creatively about how to position the stock and how you calculate toolpaths in your CAM software.
    Nice one,thats what I want to hear,I reckoned that was the way to go about it and calculate the flange to be left then simply sand off the flange,im intending to make moulds for desktop scale GRP models(I fly full size airplanes) so there is a demand from pilots for the models it would make a production line possible :-)
    Hello I've been away for a while so catching up myself.. enjoy our stay I no have :)
    Ralph Waldo Emerson
  1. NEW MEMBER: Hello from Northern Ireland
    By jonnydeen in forum New Member Introductions
    Last Post: 13-05-2012, 02:03 AM
  2. NEW MEMBER: Hello from Northern Ireland!
    By MikeMorgan in forum New Member Introductions
    Last Post: 05-05-2011, 03:29 PM
  3. NEW MEMBER: New from Northern Ireland
    By boxmaker in forum New Member Introductions
    Last Post: 25-11-2010, 06:45 PM
  4. NEW MEMBER: Hello everyone from northern ireland
    By p4tvw in forum New Member Introductions
    Last Post: 19-04-2010, 01:34 PM
  5. NEW MEMBER: Hi from Northern Ireland
    By m_morgan in forum New Member Introductions
    Last Post: 25-09-2009, 06:48 AM
