Thread: need help! choosing right kit
Hi there,
In My opinion the best way to estimate weight is the following:
First 1. Use Sketchup to build your model.
Step 2. Any components in your build must be converted into groups or components otherwise you are f****d in sketchup.
So for instance if you make a 100x100x3x 1500 solid in sketchup turn it into a group or component as soon as is made.
Step 3. if you right click a group or component and go into entity info depending on your unit setup (which should be mm for this type of work) you will see the exact cubic mm of the component.
Step 4. Go here: http://www.aqua-calc.com/calculate/volume-to-weight
If you dont see the cubic mm option click show more units and will be there.
Search for steel or aluminum or whatever and calculate.
Have a good night.
VassLast edited by HipoPapi; 16-09-2014 at 11:16 PM.
Help choosing a cnc lathe
By Hellfire in forum Marketplace DiscussionReplies: 11Last Post: 10-04-2016, 02:07 PM -
choosing a spindle.
By charlieuk in forum Spindles & Drive MotorsReplies: 15Last Post: 16-01-2014, 08:18 AM -
Choosing parts for a mill conversion
By thommy in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 21-09-2013, 05:52 PM
