Thread: need help! choosing right kit
16-09-2014 #10
mod1.5 = 1.5mm dia per tooth so with 28 tooth pinion 1 rev = 28*1.5*pi= 131mm and direct drive gives 131/200 = 0.66mm resolution per full step
for reasonable speed on a rig of that size 4000mm/min would be a good minimum with 400mm/s^2 acceleration
so (to make math easier) 3930mm/min = 30rpm of pinion so gearing 2:1 = 60rpm, 3:1=90rpm, 5:1=150rpm with resolution of .33mm, .22mm and .132mm/step respectively
Assuming a 80kg gantry and ignoring minimal friction in linear slides, the force needed to get 400mm/s^2 (0.4ms^2) acceleration is F =ma = 80 * 0.4 = 32N, which gives the torque on a 28tooth, M1.5 gear is (radius =62.5mm) = 32*.0625 = 2Nm, geared 2:1 =4Nm at motor, 3:1=6Nm, 5:1=10Nm. This ignores losses so add 10-15% for safety.
Help choosing a cnc lathe
By Hellfire in forum Marketplace DiscussionReplies: 11Last Post: 10-04-2016, 02:07 PM -
choosing a spindle.
By charlieuk in forum Spindles & Drive MotorsReplies: 15Last Post: 16-01-2014, 08:18 AM -
Choosing parts for a mill conversion
By thommy in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 21-09-2013, 05:52 PM
