    Generally enable does not need to be used so just ling the -ve on the others. ..Clive
    I learnt my lesson with floating inputs 30 years ago, so my question is - is there usually built in bias towards the enabled state in stepper drivers ?
    In my Leadshine manual it says, High level for enabling, low level for disabling. Usually left unconnected (enabled)
    So the default state you might say is 'enabled', I expect that rather than floating, the input has a pull-up resistor to keep it 'high'
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Thanks' for that it saved me replying I do use my enables but as you say it is not necessary. ..Clive
    So let me get this correct. Do I only connect the following:-
    Direction - to XD
    Pulse - to XS
    All other connections are left disconnected.
  1. Replies: 1
  2. 3 wire stepper motor drivers?
    Last Post: 17-08-2013, 10:01 PM
  3. Stepper Motor Wire Colour Codes
    By c cunningham in forum Stepper & Servo Motors
    Last Post: 26-01-2011, 02:13 PM
  4. common wire on stepper motor question
    By progomez in forum Motor Drivers & Controllers
    Last Post: 27-10-2009, 11:56 PM
  5. Stepper Motor Driver v2.3 2A $20 !!!
    By Lee Roberts in forum Motor Drivers & Controllers
    Last Post: 17-05-2009, 10:57 PM
