Yes, I know what you mean; I did find however that if you power 5V logic from the same supply you can get brownout type glitches because the 5V rail can bounce and sag if you connect and disconnect a large load on the 12V rail.
I found that doesnt happen (as much) if the resister load is pulling a couple of amps.
It may just be my dodgy skip salvage PSUs tho...
Jim
Lab-Volt 5500 B5
By CNCYAO in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 17-10-2013, 01:40 PM -
50/60 volt spindle inverter.
By GEOFFREY in forum Spindles & Drive MotorsReplies: 0Last Post: 24-12-2012, 03:58 PM -
Source for cheap/second-hand ribbed transmission belts
By irving2008 in forum Belt Drive, Pulleys & TimingReplies: 8Last Post: 05-02-2010, 02:35 AM -
Easy money
By HankMcSpank in forum General DiscussionReplies: 2Last Post: 06-07-2009, 12:39 PM -
FOR SALE: Cheap source for couplers
By progomez in forum Items For SaleReplies: 4Last Post: 19-02-2008, 06:37 AM
