Thread: Advice sought on new Mill build
26-09-2014 #11
What is the exact column length and what is the head height? Having in mind what Dean said that the head looks too narrow.
27-09-2014 #12
Column width is 250mm at the narrow end, 500mm at the bottom end. length is 1100mm, and the depth is 250mm.
27-09-2014 #13
Thickness of the plate used ?
27-09-2014 #14
10mm thick. Solidworks estimates the weight to be 147kg in that render.
27-09-2014 #15
Bolted? Forget about bolted. Welded sounds better . If you want to pour later E/G , just make pass holes prior to welding the pieces.
Making all braces same distance is not a good idea vibration wise. Introduce some progression or irregularity, in distance i mean.
What you call a torsion box will not function properly if braces are same thickness as the large plates. Plates should be thicker, or the side braces should extend more. Otherwise instead of torsion box you are creating weak spots.
Beware with that side braces cause they must be braced also between them IMO.Last edited by Boyan Silyavski; 27-09-2014 at 09:35 AM.
27-09-2014 #16
The reason i'd like it to be bolted is so it can be disassembled and lifted without more equipment. It's also easier for me from a manufacturing standpoint.
Good suggestions on the irregularity. I'll do that.
I should mention that I'm more interested in HSM, not ploughing through plates with gigantic cutters - hence the 12000rpm spindle. I would put one of those high-speed ATC integrated spindles on it if they could measure up to the performance I would get out of the servo-spindle.
27-09-2014 #17
I guessed so, about the HSM i mean. Your choice seems very good to me. Will it be 1:1 driven or variable puleys
So how you plan to move the counterweight? I mean could it be better that the counterweight slides on a cheap round rail or something, for the sake of perfection? Inside or outside?
Inside would be better, cause it would not be seen and at the same time you have to make the beam bigger, so that means stronger, tough also means heavier.
I believe that for a proper build you should forget your worry about moving the thing. I have made various mistakes thinking like that in the past. You will make it perfect, it will make money, so who cares. Any way making something more than 120kg needs special planning when moving and possibly a machine to lift it. It would cost you exactly the same if you move 200kg or 350kg or 800kg, so concentrate on the final characteristics you need.
27-09-2014 #18
Good suggestion regarding the weight.
For the spindle, the motor I will be using has a max speed of 8000rpm. The spindle has a max speed of 12000rpm.
I will put a 60T HTD5M pulley on the motor and a 40T on the spindle. I will still get a large amount of torque on the bottom end - 15.7N.m. I don't really imagine I would need more than this, given that the BF20 I have only has 3.6N.m. with a 1.8kw servo - and I have not managed to make a cut using all the available power yet.
As for the counterweight, originally I was going to have the counterweight slide on a round or HIWIN rail at the back of the column. With the new changes on the column I am starting to think that I may be better with a gas spring next to the ballscrew to push the column up.
Thoughts?
27-09-2014 #19
If your using thick enough plate for the main structure braced correctly then you shouldn't need to mess around with epoxy etc. Esp if your mainly HSM as the cutting forces are much much lower.
I wouldn't use a Gas strut and would go with counter weigth down the column centre running along some cheap round rail. Every industrial machine I've ever seen use's this method inc £250,000 5 Axis machine I recently worked on.
I'm interestd to see the spinlde and motor your going to use can you post links to it.?
27-09-2014 #20
I think he is talking about that , cause that's what i was looking at not long ago, when contemplating future mill build.
There are currently 12 users browsing this thread. (0 members and 12 guests)
BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
By njhussey in forum DIY Router Build LogsReplies: 817Last Post: 13-04-2020, 05:03 PM -
Low profile, compact work-holding solutions. Advice sought.
By Wal in forum Tool & Tooling TechnologyReplies: 23Last Post: 26-08-2016, 10:45 PM -
Z-Plunge advice sought...
By Wal in forum Machine DiscussionReplies: 3Last Post: 17-11-2013, 01:43 PM -
Advice Sought for Lathe
By Washout in forum Lathes, Lathe Rebuilding & ConversionsReplies: 13Last Post: 13-11-2013, 12:32 AM -
Help and Advice sought about new motor for my mill
By alanb in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 26-01-2012, 08:04 PM
