Thread: Advice sought on new Mill build
	24-09-2014 #1Hi Jazz,
 I can't see the attachment.
	24-09-2014 #2pouring aluminium into the tube will just make a loose slug, the ally wont bind to the column
	24-09-2014 #3
	24-09-2014 #4You want the X-axis rails attached directly to the bed, not the bearing blocks. It'll save material and keep the bearings (i.e the support) in the same place in relation to the spindle regardless of the X-axis position. The same goes for Y - orient the rails like on the machine Jazz posted.
 You've mentioned using 25mm ballscrews, but it's a bit early to be deciding that yet. On a router we'd say use 16mm screws, as the critical speed isn't a limiting factor for this size machine. However on a milling machine it can be worth using bigger ballscrews if the increased stiffness is beneficial - but you can only know that when the frame (etc) is designed.
 Yep, and it won't do a lot for damping either, which is the purpose of the epoxy...
	26-09-2014 #5Thanks for the advice everyone.
 I will tackle the column design first.
 So from the suggestions, I've moved from RHS (rolled hollow section) to a welded plate construction. the rear of the column has pockets to put the E/G mixture into, and to perhaps have another plate bolted on to seal the pockets and act as a torsion box.
 Am I on the right track?
	26-09-2014 #6What is the exact column length and what is the head height? Having in mind what Dean said that the head looks too narrow.
	27-09-2014 #7Column width is 250mm at the narrow end, 500mm at the bottom end. length is 1100mm, and the depth is 250mm.
	27-09-2014 #8Bolted? Forget about bolted. Welded sounds better  .  If you want to pour later E/G , just make pass holes prior to welding the pieces. .  If you want to pour later E/G , just make pass holes prior to welding the pieces.
 Making all braces same distance is not a good idea vibration wise. Introduce some progression or irregularity, in distance i mean.
 What you call a torsion box will not function properly if braces are same thickness as the large plates. Plates should be thicker, or the side braces should extend more. Otherwise instead of torsion box you are creating weak spots.
 Beware with that side braces cause they must be braced also between them IMO.Last edited by Boyan Silyavski; 27-09-2014 at 09:35 AM.
	27-09-2014 #9The reason i'd like it to be bolted is so it can be disassembled and lifted without more equipment. It's also easier for me from a manufacturing standpoint.
 Good suggestions on the irregularity. I'll do that.
 I should mention that I'm more interested in HSM, not ploughing through plates with gigantic cutters - hence the 12000rpm spindle. I would put one of those high-speed ATC integrated spindles on it if they could measure up to the performance I would get out of the servo-spindle.
	27-09-2014 #10I guessed so, about the HSM i mean. Your choice seems very good to me. Will it be 1:1 driven or variable puleys
 So how you plan to move the counterweight? I mean could it be better that the counterweight slides on a cheap round rail or something, for the sake of perfection? Inside or outside?
 Inside would be better, cause it would not be seen and at the same time you have to make the beam bigger, so that means stronger, tough also means heavier.
 I believe that for a proper build you should forget your worry about moving the thing. I have made various mistakes thinking like that in the past. You will make it perfect, it will make money, so who cares. Any way making something more than 120kg needs special planning when moving and possibly a machine to lift it. It would cost you exactly the same if you move 200kg or 350kg or 800kg, so concentrate on the final characteristics you need.
  BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and PlanesBy njhussey in forum DIY Router Build LogsReplies: 817Last Post: 13-04-2020, 05:03 PM
  Low profile, compact work-holding solutions. Advice sought.By Wal in forum Tool & Tooling TechnologyReplies: 23Last Post: 26-08-2016, 10:45 PM
  Z-Plunge advice sought...By Wal in forum Machine DiscussionReplies: 3Last Post: 17-11-2013, 01:43 PM
  Advice Sought for LatheBy Washout in forum Lathes, Lathe Rebuilding & ConversionsReplies: 13Last Post: 13-11-2013, 12:32 AM
  Help and Advice sought about new motor for my millBy alanb in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 26-01-2012, 08:04 PM
