Thread: Advice sought on new Mill build
28-09-2014 #31
rails and ball screws at the most will be 1500$
motor , spindle and so 2000$
500-700kg of steel 700$
mig wire, gas and so 200$
epoxy paint and so 200$
additional stuff 1000$
servo motors 1500$
That in worst case scenario, if you are careful with the design it will be more cheaper.
BUT:
-the machine would be exactly as you want it
-better built than the Chinese frame.
-Cheaper
-a lot of small things would be right, that makes a machine GREAT
Dont copy all,use it as guide lines only, build it from scratch and i assure you it will work. It seems you have done quite some research already. Plus one day next time you will like something like this , which you can buy or make your self. So why not from now plan how will fit and be prepared. The Chinese frame will not allow it without sacrificing something.
BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
By njhussey in forum DIY Router Build LogsReplies: 817Last Post: 13-04-2020, 05:03 PM -
Low profile, compact work-holding solutions. Advice sought.
By Wal in forum Tool & Tooling TechnologyReplies: 23Last Post: 26-08-2016, 10:45 PM -
Z-Plunge advice sought...
By Wal in forum Machine DiscussionReplies: 3Last Post: 17-11-2013, 01:43 PM -
Advice Sought for Lathe
By Washout in forum Lathes, Lathe Rebuilding & ConversionsReplies: 13Last Post: 13-11-2013, 12:32 AM -
Help and Advice sought about new motor for my mill
By alanb in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 26-01-2012, 08:04 PM
