    Hi everyone
    Im new here and have been converting a sieg sx2 plus mill to a cnc mill
    ive mounted my steppers but im waiting on leadscrew to be delivered to get machined for the x an y axis
    I've made a cnc controller out of a pc case and it's looking realy good
    if anyone is converting this machine I will post pics if any interest to anyone
    any ideas on where to mount my limit switches?
    and does anyone offer a machining service for lead screws and some delrin?
    Lewis
    would love to see what you have done so far, i have a x2 i am thinking of converting but would like to use ball screws if i can but first want to build a simple sub frame to mount the z axis to to get rid of the dreaded flex prblems
    HI mate
    I wanted to use ballscrews but there isn't enough room under the Y axis
    so I used a ballscrew for the Z axis but I'm guna use leadscrews for the X and Y ( haven't had them machined yet as I haven't got a lathe )
    This is my controller so far
    still need to hook the limit switches up
ID:	13434   Click image for larger version.
ID:	13433   Click image for larger version.
ID:	13432   Click image for larger version.
    This is my machine
    the controller is in the house at the moment so I can draw a nice wiring diagram for safe keeping and sharing
    My z axis mounts all made manually on this machine and ballscrew
    And nema23 425oz stepper
    I also had to move the spindle motor forward so I got a shorter belt of fleebay and made new mounts
    Got the X and Y motor mounts of eBay and had to make a 6mm spacer to compensate for the length of the lovejoy couplers
    i also made a plate to house a bearing and thrust bearing
ID:	13435   Click image for larger version.
ID:	13436   Click image for larger version.
ID:	13437   Click image for larger version.
    Just got a lathe cheaper than what people where offering to end machine 2 leadscrews for me
    So over the next couple of days I plan to clean this bad boy up and machine my leadscrews for my sx2
    i will post some pics of my progress on the lathe over the next week or two
    Need to get a single phase motor and that can run variable speed
    any ideas anyone?
    lewis
    A nice idea would be to post the pictures the correct way up. its difficult standing on your head. ..Clive
    That looks likie an Australian import....make sure it cuts the threads the right way round not upside down and back to front...
    Neil...
    Build log...here
  8. Www.Lathes.co.UK/raglan
    Stick with the 3phase motor and get a VFD, you'll regret going to a single phase.
    Started cleaning the lathe and got a bit carried away lol
    i had some paint of a steel structure I fitted in work and it's fire rated paint so I thought y not
    Need a good vfd for a 0.5 hp 3 phase motor any suggestions?
    where can I get a tool post also as the ones that came with it are home made and don't look good?
    Finished the lathe up to now I have put a misubishi vfd controller and a 3 phase motor on it an it runs well. I can control the speed easily
    I bought new bronze nuts for the top slide and crossfeed and a new top slide leadscrew
    Ive just finished my sx2 leadscrews and am waiting for some alloy to be posted and then I can make the mounts for the delrin nuts that I've also finished
ID:	13950Click image for larger version.
    FINALY SOME PROGRESS
    What is the easiest way to learn how to draw a part then turn it to a g-code for mach3 ?
    Or am I best buying a digitizing probe of fleebay from US for $199
  1. CONVERSION: Amadeal25LV CNC Conversion
    By StevenT in forum Conversion Build Logs
    Last Post: 04-05-2020, 11:47 AM
  2. FOR SALE: HOBBYMAT BFE 65 / CNC conversion.
    By manofgresley in forum Items For Sale
    Last Post: 11-11-2018, 10:21 PM
  3. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  4. Sieg sx2 conversion kit
    By Goldigger in forum Milling Machines, Builds & Conversions
    Last Post: 24-04-2011, 07:42 PM
  5. A little conversion tool
    By D-man in forum Computer Software
    Last Post: 18-12-2010, 04:58 PM
