    I'm still not understanding what I am looking at.
    The plasticiser is the bit that converts granular plastic to melt. This has to connect to the mould, inject the melt, hold the pressure until something freezes, gates, sprue, whatever, disconnect from the mould and melt more granules.
    Generally there are 3 ways in to a mould. On the mould parting line, through a sprue bushing, through heated runners where the melt never sets.
    I thought that sprue bushing was usually a flat on flat seal with maybe a puff of cold air if stringing got too bad.
    I thought I saw something like a countersunk screw head shaped cavity in your picture which would be fine and dandy if it was on the mould parting line because you wouldn't have to worry about getting it all out before the next shot.
    Original scan is a detail view from this sheet
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    So you have two tie bars 4" apart. The platens have 3" indents presumably to locate the mould halves. The moving platen (top) has a 2" hole through which the ejector pins pass.
    Can we assume the fixed platen (bottom) has a similar hole, which isn't shown, and the nozzle comes up from below, the drawing Y axis, through that hole. It does not come in from above, the drawing Z axis, to hit the parting line.
    Yes the nozzle does come up from below in the diagram, but I have it round the wrong way, it needs to be rotated 90 degrees. This is a horizontal machine.
    ADD ME ON FACEBOOKS
    http://www.ebay.co.uk/itm/1411621341...%3AMEBIDX%3AIT
    Bought this 40mm long bar from ebay, hopefully I will be able to chuck it up in the lathe and still get enough material sticking out to make a blank for the injection molder.
    ADD ME ON FACEBOOKS
    IIRC I have about 4 or 5 feet of 4 1/4" 7075 T6 somewhere in my workshop.
    Sounds tempting Robin but I don't think my myford will be able to work something that big.
    ADD ME ON FACEBOOKS
  1. Plastic injection mold making forum?
    By gavztheouch in forum Moulding Machines
    Last Post: 13-10-2022, 11:31 AM
  2. New toy - Arburg injection moulder
    By Robin Hewitt in forum Moulding Machines
    Last Post: 26-10-2014, 11:59 PM
  3. RFQ: Any Injection Moulders on here, before I buy Chinese ?
    By Bazzer in forum Projects, Jobs & Requests
    Last Post: 18-05-2013, 11:25 AM
  4. DIY Injection moulding by JR Hartley.
    By HankMcSpank in forum Moulding Machines
    Last Post: 04-01-2013, 12:41 AM
  5. Proxxon MF70 for making injection molds
    By forrest in forum Moulding Machines
    Last Post: 11-04-2012, 11:30 PM
