http://www.ebay.co.uk/itm/1411621341...%3AMEBIDX%3AIT
Bought this 40mm long bar from ebay, hopefully I will be able to chuck it up in the lathe and still get enough material sticking out to make a blank for the injection molder.CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
10-10-2014 #2
IIRC I have about 4 or 5 feet of 4 1/4" 7075 T6 somewhere in my workshop.
13-10-2014 #3
Sounds tempting Robin but I don't think my myford will be able to work something that big.
ADD ME ON FACEBOOKS
18-10-2014 #4
Anyone got any ideas as to what a custom made carbide or hss tool would cost to cut the profile for my injection mold "nozzle gate" as per drawing?
ADD ME ON FACEBOOKS
19-10-2014 #5
Can you make one of these
D bit.doc
19-10-2014 #6
I am still not understanding, isn't this shape ground into steel perfection for you as part of the sprue bushing?
19-10-2014 #7CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
23-10-2014 #8CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
23-10-2014 #9
Hi Gav
Yes it's made from silver steel which is a high carbon steel available in metric & imperial sizes and is ground finish and readily available. The bar is in it's annealed state and you manufacture your required tool then heat it to cherry red and quench, then polish the tool and apply heat to the end of the shaft and you will see the polished surface change to a straw color as this works it's way to the cutting part of the tool quench in cold water and that's it tempered.
Looking @ your drawing that profile is situated in the sliding part of the jobby that the mould goes into,is that correct ?
05-05-2016 #10
Plastic injection mold making forum?
By gavztheouch in forum Moulding MachinesReplies: 26Last Post: 13-10-2022, 11:31 AM -
New toy - Arburg injection moulder
By Robin Hewitt in forum Moulding MachinesReplies: 13Last Post: 26-10-2014, 11:59 PM -
RFQ: Any Injection Moulders on here, before I buy Chinese ?
By Bazzer in forum Projects, Jobs & RequestsReplies: 11Last Post: 18-05-2013, 11:25 AM -
DIY Injection moulding by JR Hartley.
By HankMcSpank in forum Moulding MachinesReplies: 26Last Post: 04-01-2013, 12:41 AM -
Proxxon MF70 for making injection molds
By forrest in forum Moulding MachinesReplies: 8Last Post: 11-04-2012, 11:30 PM
