Thread: cnc 3040 and mach3 problems
Not enough info to help John.? Where does the squealing seem to be coming from.? Problems like this are quite hard to diagnose thru words would it be possible to take a video.
Will need to know at least how the machine is setup in software. So native units and Steps per, velocity, acceleration.
Also details on the electronics. Does it have the 3 axis all in one board or the individual drives.? Pics would help.
24-09-2014 #2
native units inches....steps per 12800...velocity 1999.8....acceleration 200....steps pulse10...dr pulse 3....3 axis all in one board hope this helps..john..
24-09-2014 #3
squealing seems to come from all the axis,s
24-09-2014 #4
24-09-2014 #5
its not the motors or screws I think it is the linear bearings..john..
24-09-2014 #6
24-09-2014 #7
That's step per indicates far too high micro stepping. It would appears to set as if your drives are set at 3200 micros steps and using a 4mm pitch screw.
I very much doubt these drives will be set at that figure and if they are it needs changing to half that and either 1600 or 2000 definatley not more.
Suspect that the steps per is wrong for the drives and if that was the case then the machine will move the wrong amount.
Try this.! Type G0 x0 into MDI window and see how far it moves. This will tell you if set wrong or not. It should move 1inch but I suspect it will only move 1/2".?
if wrong then easy way to save you messing around is to use the built in Set Steps per option on the settings tab and measure the distance moved. Mach will then enter the correct amount for you.
If it's correct then I would change the drives to a lower micro stepping because that will be too high for these drives and put more strain on the PC parallel port.
24-09-2014 #8
From a similar machine manual they have it set to 400 steps per (that's for a metric machine)
It had 1404 trapezoidal screws, microstepping likely set to 8, motors were 1.8deg.
step per = "The number of steps Mach3 must send for one unit of movement"
So for a metric machine one unit of movement = 1 mm;
a 1.8 deg motor has 360 / 1.8 = 200 steps per rev.
with microstepping set to 8, 200 x 8 = 1600 steps per rev
with a screw pitch of 4mm, 1mm movement = 1/4 turn
1600 x 0.25 = 400 steps per
So for an imperial machine one unit of movement = 1 inch;
with a screw pitch of 4mm, one inch movement = 25.4/4 = 6.35 turns
1600 x 6.35 = 10160 steps per
All of that assumes a 1:1 ratio between motor and leadscrewLast edited by EddyCurrent; 24-09-2014 at 01:52 PM.
11-10-2014 #9
Mach3 PC problems, help please....
By Davek0974 in forum Plasma Table MachinesReplies: 13Last Post: 30-01-2014, 07:05 PM -
Need repacement controller for CNC 3040
By RoyT in forum Control Hardware & SystemsReplies: 4Last Post: 22-01-2014, 06:16 PM -
Ebay 3040 issue with mach3 - incorrect scale when machining?
By Wayne Kinney in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 04-03-2012, 12:17 PM -
NEW MEMBER: New Member with a 3040 CNC
By Tug in forum New Member IntroductionsReplies: 7Last Post: 26-09-2011, 12:15 PM -
homing problems in mach3
By johngoodrich in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 17-09-2011, 08:28 PM
