27-01-2023 #37
After m_c had said about the inrush limiter I have been looking at various options but I have found this on amazon and just wondering if I could use that
https://smile.amazon.co.uk/gp/produc...SBGN3D0P&psc=1
The Description shows
Soft start for power tools with brush motor from 220-250 volts max. 12 A (tested to 2500 watts)
Includes extensive accessories such as cable extensions and plugs/terminals
Suitable for angle grinders, table saws, hand circular saws, routers, chop saws and mitre saws
Restriction of the inrush current, protects the bearings
Compatible with machines of leading manufacturers
or if there is a better way for the inrush limiting.
thanks
Rob
Welding 5-8mm steel box-section tubes
By techcobweb in forum Welding, Brazing & EquipmentReplies: 9Last Post: 17-07-2018, 05:53 PM -
FOR SALE: SFU1605 Ballscrews and Nuts 950mm, 1150mm and 1500mm, SBR16 950 Rail, SBR20 1150 Rail
By Maccydu in forum Items For SaleReplies: 1Last Post: 12-12-2015, 09:55 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Straightness of steel/alumunium box section
By Jonathan in forum Linear & Rotary MotionReplies: 50Last Post: 17-09-2010, 07:53 PM -
Machining Ballscrews with a mini lathe (& ballscrew support questions)
By HankMcSpank in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 16-02-2010, 12:22 AM
