    Quote Originally Posted by grain_r View Post
    I am really sorry when you say move the rails back do you mean so that the spindle is inline with the upright box section of the gantry ? would it maybe worth going for something like 100x50mm box section for the sides and then put the 50x50 towards the rear to the spindle so it is more inline with the uprights of the gantry, I'm sorry if I've misunderstood.
    No was meaning offset back something like this for better centre of gravity and balanced bearing loads while cutting.Click image for larger version.
    Regards bearing distance then I work on Half the travel required.!
  1. Welding 5-8mm steel box-section tubes
    By techcobweb in forum Welding, Brazing & Equipment
    Last Post: 17-07-2018, 05:53 PM
  2. Replies: 1
    Last Post: 12-12-2015, 09:55 PM
  3. Maximum size of box section, Stacking box section, Construction Angle
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 01-02-2013, 05:29 PM
  4. Straightness of steel/alumunium box section
    By Jonathan in forum Linear & Rotary Motion
    Last Post: 17-09-2010, 07:53 PM
  5. Machining Ballscrews with a mini lathe (& ballscrew support questions)
    By HankMcSpank in forum Lead Screws, Nuts & Supports
    Last Post: 16-02-2010, 12:22 AM
