22-10-2014 #11
Hey guys Thanks very much for the replies, Unfortunately I was a silly boy and bought the supported rails kit before I knew anything about the subject from Aliexpress. the plan being I will use what I have for now but then look to either create another or upgrade to rails. I have made it wider also so that I can slide work pieces around a little and work with larger materials and then make a second continued cut although most of the things I do will be sheet material and smaller pieces but I wanted an all-rounder for things like my daughters dolls house I intend to make with the machine and other toys too for her and me !
I didn't even think about the tensioning in all honesty that is a very good point I will make it on a movable faceplate. I couldn't think of a different way for the box for the ballnuts otherwise the other option being the ali route but though this might be better on the strength I might be able to make a silicone hose to the grease maybe although I'm not sure if it would just pop off.
I will have a good think to see if I can make those better
Thanks so much guys.
Welding 5-8mm steel box-section tubes
By techcobweb in forum Welding, Brazing & EquipmentReplies: 9Last Post: 17-07-2018, 05:53 PM -
FOR SALE: SFU1605 Ballscrews and Nuts 950mm, 1150mm and 1500mm, SBR16 950 Rail, SBR20 1150 Rail
By Maccydu in forum Items For SaleReplies: 1Last Post: 12-12-2015, 09:55 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Straightness of steel/alumunium box section
By Jonathan in forum Linear & Rotary MotionReplies: 50Last Post: 17-09-2010, 07:53 PM -
Machining Ballscrews with a mini lathe (& ballscrew support questions)
By HankMcSpank in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 16-02-2010, 12:22 AM
