23-10-2014 #10
Hey Neil,
I'm sorry about that your certainly not teaching granny, I gone more on the lines well that seemed to make the shape I want at the time. I will certainly group then from now on the makes a lot of sense I tried to do it with layers instead of the grouping and then selecting the layer to move things around. Although I certainly got further on sketch-up than on Autocad 3d up to now that's next weeks job then (Well Maybe)
Thanks Eddy that sounds like it would be worth a look at I also though about a plasma cutter for the future for stainless although thats as far as I've gone with it. I appologize not having used one of these things would I be able to set a home and then use different paths for the further cuts ? I'm certainly not worried about having to swap the spindle around between then that would get the hoped for cutting area when I forgot about the bearing blocks when I felt like a shopping trip before I knew anything at all.
thanks
Rob
Welding 5-8mm steel box-section tubes
By techcobweb in forum Welding, Brazing & EquipmentReplies: 9Last Post: 17-07-2018, 05:53 PM -
FOR SALE: SFU1605 Ballscrews and Nuts 950mm, 1150mm and 1500mm, SBR16 950 Rail, SBR20 1150 Rail
By Maccydu in forum Items For SaleReplies: 1Last Post: 12-12-2015, 09:55 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Straightness of steel/alumunium box section
By Jonathan in forum Linear & Rotary MotionReplies: 50Last Post: 17-09-2010, 07:53 PM -
Machining Ballscrews with a mini lathe (& ballscrew support questions)
By HankMcSpank in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 16-02-2010, 12:22 AM
