03-01-2016 #10
Typically you would spot drill the hole first with a spotting drill bit (like a normal bit but shorter and so stiffer) or a center drill bit, a smaller diameter drill bit maybe used as/or well, just take your time as they snap easily at those sizes.
I can't see this would be a problem with your bench drill though, would continue to use it instead of going free hand personally.
.Me
Edit: Not sure if you've settled on a Z Axis design yet but here is a link to how I've done mine using 20mm plate and TBR16 round rails:
Link: http://www.mycncuk.com/album.php?albumid=387Last edited by Lee Roberts; 04-01-2016 at 12:00 AM.
Welding 5-8mm steel box-section tubes
By techcobweb in forum Welding, Brazing & EquipmentReplies: 9Last Post: 17-07-2018, 05:53 PM -
FOR SALE: SFU1605 Ballscrews and Nuts 950mm, 1150mm and 1500mm, SBR16 950 Rail, SBR20 1150 Rail
By Maccydu in forum Items For SaleReplies: 1Last Post: 12-12-2015, 09:55 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Straightness of steel/alumunium box section
By Jonathan in forum Linear & Rotary MotionReplies: 50Last Post: 17-09-2010, 07:53 PM -
Machining Ballscrews with a mini lathe (& ballscrew support questions)
By HankMcSpank in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 16-02-2010, 12:22 AM
