03-09-2016 #81
How do you propose to get the main axis shafts level and parallel with each other? Commercial companies using this style of frame will have accurate jigs to hold the frame in position while they weld it. Special purpose machine makers mount rails onto a flat ground plate, which is mounted onto the frame, to ensure flatness. With the flat plate and one shaft mounted you could check parallelism using a dial indicator to locate the position of the other shaft.
12-09-2016 #82
Hey colin
Sorry for the Delay in replying. I have given myself room to move components for small adjusting of plates which is lucky too because as previously said I just cant get the holes as close as I would like. although I centre punch and then centre drill and then go larger but I think with my newer drill press it has got better. But i have made 6mm holes in the plates that bolt to the m5 tapped holes so that will give me a small amount of movement.
I have a dial indicator to get as close as I can although I need to find a long enough straight edge to trust and then using the Vernier caliper too.
I will then be able to then flatten the spoil board once everything is running so it won't matter if the machine is a small part of a mm out because it will al be parallel with itself and also the work piece.
Well that's the plan anyway. I will be using Epoxy for the rails to get the top rails flat running a channel between the rails and this will then self level.
i think then it will be a lot of fiddling about to chase every last 0.0 of mm
I would be great to have those known flat and precise equipment of the manufacturers have but money would never allow for it sadly.
thanks
RobLast edited by grain_r; 12-09-2016 at 08:35 PM.
12-09-2016 #83
What about using a laser level and laser distance measure. If you are careful you could use a sheet of glass to check for level.
12-09-2016 #84
12-09-2016 #85
Best look for old double glased unit the edges are taped and safer, wear gloves and glasses.
08-11-2017 #86
Well still building the frame but also learning as I go about the electronics and everything else.
I am looking at the pulley's to use dean said that a 2:1 gearing ratio is good for a 1605 Ballscrew but does it matter how many teeth are on the pulley as long as it is 2:1 on the otherside of the motor I can't find any threads that show how to work it out.
I am looking at using Nema23 4nm from CNC4You which look to be low inductance and high torque also nothing really shows the torque curves to show if it is usable power through the range.
Has anyone used these motors at all ?
I know that it is best to wait for buying things but my year end accounts are up so trying to make sure I can buy the bits before then.
I have now ordered the 4 Leadshine AM882s because I will be using duel screws on the X.
I'm now ordering the Hiwin rails from Fred because its taking forever to build if I use the supported rails I don't think it would ever get upgraded so do it one do it right.
So its back to cad and make the changes.
08-11-2017 #87These are the one's to go for, good choice and the AM882's are also good.I am looking at using Nema23 4nm from CNC4You which look to be low inductance and high torque also nothing really shows the torque curves to show if it is usable power through the range.
In general 1605 screw on Z and 1610 on X and Y . I have used 1:1 on X and 2:1 on X & Y (router twin screw)..Clive
08-11-2017 #88
Hey Clive
Brilliant thank you very much for that I will get them on order.
I have looked on the cnc4you and the grubscrew pulleys but i'm not sure if there is a formula to stick to or is it not the teeth but the ratio that is important. I'm sorry I have never got to grips with pulleys.
I think the original 1605 ballscrews because now I'm going with Hiwin rails i'm going to maximise the space.
09-11-2017 #89
09-11-2017 #90
Thanks Clive I will have a look at the 30 Teeth. Like all things I went on the theory the More power the better :)
Welding 5-8mm steel box-section tubes
By techcobweb in forum Welding, Brazing & EquipmentReplies: 9Last Post: 17-07-2018, 05:53 PM -
FOR SALE: SFU1605 Ballscrews and Nuts 950mm, 1150mm and 1500mm, SBR16 950 Rail, SBR20 1150 Rail
By Maccydu in forum Items For SaleReplies: 1Last Post: 12-12-2015, 09:55 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Straightness of steel/alumunium box section
By Jonathan in forum Linear & Rotary MotionReplies: 50Last Post: 17-09-2010, 07:53 PM -
Machining Ballscrews with a mini lathe (& ballscrew support questions)
By HankMcSpank in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 16-02-2010, 12:22 AM
