    Thanks Clive I will have a look at the 30 Teeth. Like all things I went on the theory the More power the better :)
    Lives in Plymouth, United Kingdom. Last Activity: 20 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I'm using two 3Nm motors to drive my X axis. 68V PSU.Steel gantry, with spindle, etc, probably weighs around 50kg. 2005 ballscrews, driven 1-1 through (from memory) 20T pulleys. Gives me about 5m/min rapids. That corresponds to about critical speed of ballscrews and corner speed of motors. 2010 might give me a bit more speed but probably at the cost of acceleration which is more useful if you are doing fiddly detail cutting.
  1. Welding 5-8mm steel box-section tubes
    By techcobweb in forum Welding, Brazing & Equipment
    Last Post: 17-07-2018, 05:53 PM
  2. Replies: 1
    Last Post: 12-12-2015, 09:55 PM
  3. Maximum size of box section, Stacking box section, Construction Angle
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 01-02-2013, 05:29 PM
  4. Straightness of steel/alumunium box section
    By Jonathan in forum Linear & Rotary Motion
    Last Post: 17-09-2010, 07:53 PM
  5. Machining Ballscrews with a mini lathe (& ballscrew support questions)
    By HankMcSpank in forum Lead Screws, Nuts & Supports
    Last Post: 16-02-2010, 12:22 AM
