    Sounds like you've done a good research job, I think 20mm ball screws may be in order and if you use good digital drivers for the stepper motors then speed should be achievable.
    There's not much to say until the pictures are up.
    Thanks Eddy. I have very much enjoyed reading and learning from your contributions to this site. For some reason I cannot load dwg files, so have reverted to pdf format. Attached are images and Excel spreadsheet of materials:
    Materials and Mass 20140930.xls
    I look forward to your and other's feedback.
    Attached Thumbnails Attached Thumbnails Right View.pdf   Top View.pdf   Perspective View.pdf   Gantry Right View.pdf   Front View X Axis and Gantry close up.pdf
    I have been asked to upload JPEG files. Here they are (slightly different perspectives but from same drawing). If someone can advise what the preferred file format for graphic uploads is, then I will stick with that going forward.
ID:	13501   Click image for larger version.
Name:	Gantry Close Up.jpg
ID:	13502   Click image for larger version.
Name:	Perspective View with Plasma.jpg
ID:	13503   Click image for larger version.
ID:	13504   Click image for larger version.
ID:	13505   Click image for larger version.
ID:	13506   Click image for larger version.
Name:	X and Y Axis Close Up.jpg
  1. My plasma build 8 x 4
    By drumsticksplinter in forum DIY Plasma Build Logs
    Last Post: 01-02-2014, 10:39 PM
  2. my plasma build mk2
    By oadamo in forum DIY Plasma Build Logs
    Last Post: 08-06-2011, 10:25 PM
  3. my first plasma build
    Last Post: 31-12-2010, 07:15 PM
  4. My first Plasma build
    By D-man in forum Plasma Table Machines
    Last Post: 10-07-2010, 02:27 AM
  5. plasma build log - sort of
    By mike techserv in forum DIY Plasma Build Logs
    Last Post: 23-04-2009, 10:15 AM
