    Hello all,
    After spending a long long time designing my CNC router, I feel I am now at the time to start getting some quotes for the aluminium parts I require. The design is not 100% finalised but I only anticipate very small changes here and there.
    See full build thread here: http://www.mycncuk.com/threads/5549-...e-Materials%29
    Essentially all parts require machining on top and bottom. I will update this thread ASAP with screenshots of each part to give a better idea. I can also, of course, provide STEP files for each part.
    I am looking for an "all in" cost including material.
    Part 1 - Gantry Side Plate (Left)
    Quantity: 1
    Material: Aluminium
    Thickness: 20mm
    Outside Dimensions: 255mm x 160mm
    Part 2 - Gantry Side Plate (Right)
    Quantity: 1
    Material: Aluminium
    Thickness: 20mm
    Part 3 - Y Axis Bearing Mount Plates
    Quantity: 2
    Material: Aluminium
    Thickness: 15mm
    Outside Dimensions: 160mm x 60mm
    Part 4 - X Axis Carriage Plate
    Quantity: 1
    Material: Aluminium
    Thickness: 20mm
    Outside Dimensions: 231mm x 130mm
    Part 5 - X Axis Bearing Plate (Top)
    Quantity: 1
    Material: Aluminium
    Thickness: 20mm
    Outside Dimensions: 130mm x 100mm
    Part 6 - X Axis Bearing Plate (Bottom)
    Quantity: 1
    Material: Aluminium
    Thickness: 20mm
    Outside Dimensions: 130mm x 55mm
    Part 7 - Y Axis Ballnut Mount
    Quantity: 1
    Material: Aluminium
    Thickness: 20mm
    Outside Dimensions: 97.5mm x 40mm
    Part 8 - NEMA Motor Mount
    Quantity: 3
    Material: Aluminium
    Thickness: 10mm
    Outside Dimensions: 95mm x 70mm
    Part 9 - Motor Mount Extrusion Bracket
    Quantity: 3
    Material: Aluminium
    Thickness: 15mm
    Outside Dimensions: 40mm x 70mm
    Part 10 - Spindle Z Mount
    Quantity: 1
    Material: Aluminium
    Thickness: 20mm
    Outside Dimensions: 115mm x 130mm
    Any questions, please don't hesitate to ask!
    Thanks,
    Dave
  1. RFQ: Regular supplier of aluminium parts CNC - opportunity
    By emohawk11 in forum Projects, Jobs & Requests
    Last Post: 09-08-2014, 12:17 PM
  2. NEW MEMBER: CNC Router Parts
    By CRP in forum New Member Introductions
    Last Post: 29-10-2013, 02:37 AM
  3. MDF CNC Router plans / parts for home build beginners
    By HiltonSteve in forum Gantry/Router Machines & Building
    Last Post: 10-06-2012, 02:33 PM
  4. RFQ: Parts CNC machined from Aluminium or Brass
    By egimson in forum Projects, Jobs & Requests
    Last Post: 02-04-2012, 08:50 PM
  5. RFQ: Aluminium parts for my first cnc mill.
    By everyreasonto in forum Projects, Jobs & Requests
    Last Post: 17-07-2011, 11:36 PM
