15-10-2014 #2
Maybe this thread would be useful ?
http://www.instructables.com/answers...er-dc-voltage/Last edited by EddyCurrent; 15-10-2014 at 01:51 PM.
15-10-2014 #3
I have just made and installed a control panel for a glass blower friend. The labels for the modules are fibreglass circuit board. If you put LEDs behind them the lettering shines though beautifully. Next phase of project ??? I might even go full steampunk. maroon and green with gold striping and ornate Ibis carvings in the blank areas of the panels and , of course I would have to change the stainless metric button head screws to whitworth bronze slothead.
The picture btw is a screenshot of an IP camera set up to view the panel from anywhere.Last edited by cropwell; 15-10-2014 at 04:54 PM.
15-10-2014 #4
Nice work on the furnace control, just for those still not disillusioned with LEDs have a look at http://www.onsemi.com/pub_link/Colla...I45020JZ-D.PDF http://www.onsemi.com/pub_link/Colla...SI45030A-D.PDF and there are versions of this with different current and voltages
I'm still trying to work out how to use a illuminated led as a switch if any one has done this let me know
15-10-2014 #5
15-10-2014 #6
I think you might mean as a touch switch - I presume you could use a metal cased led on an insulating panel as the sensor on a touch switch circuit
https://www.google.co.uk/search?q=to...55%3B761%3B504
Pick one !Last edited by cropwell; 15-10-2014 at 05:20 PM.
15-10-2014 #7
no, not a metal can version a basic 5mm LED .....my thoughts the LED stays on, capacitance on one of the LED pins is the switch so just touch the resin or get close and the switch action operates the led to turn off or any output can be turned off
RFQ: Daft Punk Build
By FIREWIRE in forum Projects, Jobs & RequestsReplies: 0Last Post: 19-04-2013, 02:34 AM -
I promise I will stop asking daft question soon. Ish.
By D.C. in forum Gantry/Router Machines & BuildingReplies: 27Last Post: 15-10-2012, 11:37 PM -
A daft question about vibration damping
By D.C. in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 11-10-2012, 09:57 AM -
NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
By m0nk3hjam in forum New Member IntroductionsReplies: 6Last Post: 17-08-2010, 02:32 AM -
High speed spindle
By leadinglights in forum Tool & Tooling TechnologyReplies: 0Last Post: 27-04-2010, 09:23 PM
