@GEOFFREY
Here's an extract from my breakout board manual
"The charge pump uses the 12 kHz signal from the parallel port generated by the CNC software to operate a logic circuit that gives an active low output. Any piece of machinery that uses powerful motors can be dangerous if controlled by a computer that can be in an unknown state while being powered up or in a software crash condition. Using the charge pump circuit to disable power to motors is a safety device in that it only operates when the software is running correctly and under user control. The charge pump circuit is also used to disable the output signals so even if your stepper boards do not have an enable pin they will be disabled automatically when the charge pump signal is not present."Spelling mistakes are not intentional, I only seem to see them some time after I've posted
The Following User Says Thank You to EddyCurrent For This Useful Post:
EMCO Spindle Control
By Pete92 in forum Spindles & Drive MotorsReplies: 1Last Post: 06-11-2013, 10:20 PM -
Spindle Speed Control
By cncJim in forum Spindles & Drive MotorsReplies: 15Last Post: 18-06-2013, 07:53 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
Help with spindle control
By wizzy in forum Spindles & Drive MotorsReplies: 4Last Post: 12-02-2011, 12:51 AM -
CNC spindle control VFD problem
By djc in forum Motor Drivers & ControllersReplies: 1Last Post: 13-09-2009, 09:26 PM
