01-10-2014 #7
My simplistic brain understands it thus :- Mach3 or other control software puts out a signal that says it is operating. That signal 'pumps up' a capacitor on the BOB. when that capacitor reaches a certain voltage it enables the circuits, so motors will move, relays will click and spindles will spin. Others may offer a more technical explanation, but my mind can't cope with too much.
I never got it working on the BOB, probably because it was never set up properly on the output pinout in Mach3. The company in Devon that I got the machine from sent me an xml file (Mach3 parameters) and I just used that, when the charge pump didn't work, in retrospect it appears they didn't have a clue why. So it was disabled on the BOB and left at that. At the moment I have not got the machine computer connected up, so I can't look into how it was set up (or not, as the case may be) in Mach3. I will bet that it wasn't enabled !!!Last edited by cropwell; 01-10-2014 at 10:22 PM.
The Following User Says Thank You to cropwell For This Useful Post:
EMCO Spindle Control
By Pete92 in forum Spindles & Drive MotorsReplies: 1Last Post: 06-11-2013, 10:20 PM -
Spindle Speed Control
By cncJim in forum Spindles & Drive MotorsReplies: 15Last Post: 18-06-2013, 07:53 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
Help with spindle control
By wizzy in forum Spindles & Drive MotorsReplies: 4Last Post: 12-02-2011, 12:51 AM -
CNC spindle control VFD problem
By djc in forum Motor Drivers & ControllersReplies: 1Last Post: 13-09-2009, 09:26 PM
