05-10-2014 #2
looking good
some will advise you to add diagonal bracing to the frame and swap around the profile rail and blocks on your z axis so the rails on the back of your front plate.
I also used a lump of box section for my Y axis but none of the sides were flat/even enough to mount profile rail straight to so I plated it then had it ground flat...that was for a fixed gantry though so weight wasn't an issue..Last edited by dazza; 05-10-2014 at 03:13 PM.
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM
