    Thanks for the suggestions.
    For the gantry, i'm going to have it stress relieved and then milled back. For the frame, i'm going to use an epoxy bed - i think that getting the frame milled flat would be very, very expensive.
    I'll add some diagonal bracing to the frame too.
    As for the ballscrews, I think you're right Jonathan - the critical speed for this design in a 16mm ballscrew would be around 1600rpm. That's probably near the limit of what the steppers can provide.
    I will thicken the plate used for the Z axis - I would rather not reverse the rails and blocks.
    I've added braces to the legs in all directions.
    I've also increased the thickness of the Z axis plate that will have the spindle connected to it. Previously it was 16mm, now it's 25.
    I have a question regarding the motor selection:
    I have 600W AC servos in my possession that I'd like to use for this build instead of the NEMA 34 motors.
    They have a continuous torque rating of 1.91N.m. - and with the 10mm lead ballscrews, I will get 1200N of linear force.
    The gantry and all components attached to it weighs in at 100kg. From dual-driving the gantry, the combined linear force of both motors amounts to 2400N.
    Is this enough to move the gantry with a reasonable factor of safety?
    What is your servo encoder count per revolution?
    10,000 per revolution.
  1. Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
    By Wejjmeister in forum Gantry/Router Machines & Building
    Last Post: 03-01-2016, 12:45 AM
  2. BUILD LOG: Steel frame cnc router design/build
  3. BUILD LOG: First steel diy CNC router build
  4. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
  5. FOR SALE: Strong steel welded base with ground flat surface.
    By black5f in forum Items For Sale
    Last Post: 14-01-2012, 07:20 PM
