I wouldn't think so, also this needs thinking about more because it now seems overkill to build a 3 axis machine for such a simple operation.
It's made more difficult due to the pipe being steel, if it was wood for example I would make a larger tube to go over it, this larger tube would have the required slots already cut in it then I would use a router with a guide bush to follow the slots while cutting the workpiece tube inside, if you follow my drift.Last edited by EddyCurrent; 13-10-2014 at 06:56 PM.
13-10-2014 #2
Plasma is what you need. The forces to cut steel, even with Slot drill are much more than you probably realise if your suggesting to use Dremel type spindle.
The spindle will need to be slow spinning with plenty of torque. The Milling head will need to be very strong and clamp the pipe tight to handle the forces involved.
While Plasma cutter will cost more than spindle the cycle times for jobs will be much faster if you used plasma and the overall machine strength can be lot less as there are no cutting forces involved saving money on the build. These two things alone will outway the expense and pay back down the line.
No brainer to me Plasma is the way to do this.! . . . . . Just look around every machine doing this job uses Plasma or Laser.!!!Last edited by JAZZCNC; 13-10-2014 at 08:02 PM.
NEW MEMBER: Jig angle head expert look at my PICTURE please!
By hoezap in forum New Member IntroductionsReplies: 6Last Post: 25-07-2012, 05:09 AM -
Very simple for special tool expert … heeeelp!
By hoezap in forum Tool & Tooling TechnologyReplies: 0Last Post: 14-07-2012, 08:57 AM -
new build, need guidance on electronics etc
By deannos in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 14-11-2010, 03:38 PM -
Guidance please ...
By Wobblybootie in forum General ElectronicsReplies: 4Last Post: 13-11-2010, 01:30 PM -
NEW MEMBER: Rookie needs advice.
By I need a dog in forum New Member IntroductionsReplies: 1Last Post: 24-10-2009, 07:00 PM
