11-10-2014 #11
11-10-2014 #12
12-10-2014 #13
12-10-2014 #14
Hi Dean, sorry to be picky cos I know what you meant but I think if you read what you wrote again its somewhat ambiguous IMHO to others who may be less knowledgeable.
"You could also..." implies an alternative to the previous statement. If you'd said " In the control box you could also...." or " which is good to use but only in the control box" then I'd agree with you 100%. :)Last edited by irving2008; 12-10-2014 at 05:53 AM.
12-10-2014 #15
Erm yes you are being picky and on reading again I Do and Don't agree.!! If you read it like this like it was meant.
Then it's clear I meaning to be only used for signal wires which Cat5 can safely be used out side the machine as often Limits, homes and e-stop are often fixed so don't move.!. . . YES you could get more picky and say some travel but come on how far do you go wiping folks arse's they have to employ some common sense.?
I will thou agree that I should have clarified about not using on cables moving or said use CY for moving cables. SO SORRY FOLKS LET ME CLARIFY
!!! DONT USE CAT5 FOR MOVING CABLES !!!!! ALWAYS USE CY CABLE !!!
10' x 5' Plasma table design
By Kerryfisher in forum Plasma Table MachinesReplies: 4Last Post: 20-02-2013, 09:28 AM -
Homebuilt Plasma Table Modifications
By Normsthename in forum DIY Plasma Build LogsReplies: 11Last Post: 27-07-2010, 12:58 AM -
RFQ: RFQ: Plasma Table
By D-man in forum Projects, Jobs & RequestsReplies: 3Last Post: 04-07-2010, 11:08 PM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM -
Plasma table 2m x 1m
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 9Last Post: 19-05-2009, 12:48 PM
