Hi Sven. Thanks for you post. It makes sense to do the machining in house. However when setting up business if you have not got the capital to invest then it is a big risk before you know the business is going to work. Also have to remember there is more than the cost of the machine, there is the maintenance, new bits, ordering materials, paying someone to operate the machine and the cost of a big workshop to give it a home. I'm sure I will invest once I get the business up and running and the numbers add up, once I know the product sells I'll take the leap. Do you know anything about the technicalities of CNC routing? How to get the prices down or how to deign MDF components so they are quicker to cut? Or maybe I am clutching at straws???
23-10-2014 #2
Where are you? Give some more details of the job. I'll be happy to compare quotes as I'm doing the same thing at the moment.
Timbmet Stonehouse quoted me £80 cutting fee for a one off 2800x2070 sheet, a mixture of cnc and sawing. Their cnc is only 3000x1500. Was told it would be less for more boards. I suggested repeat orders should be cheaper due to no programming needed, but they didn't agree! I will work on them after my first job.
25-10-2014 #3
It's not the coding that takes time it's the fixturing of the machine and if the machine doesn't have tool changer some one as to baby sit the machine changing tools.! . . . In some cases changing the tool can take longer than the tool actualy cuts for, So if there are many tool changes involved then on manual tool change machine it does add up the time and can be more trouble than it's worth for a single board. This is why they won't want to lower price for single board.
24-10-2014 #4
Without knowing exactly what you're doing, it's difficult to give recommendations. Every job is potentially different, and can present it's own challenges.
The big difference in pricing you may be seeing may just be due to the fact that some people don't know what they're doing, or how much they should be charging (at the low end). The high prioces may hjsut mean they don't want your business. I'd go with the cheapest one, and see how they're quality is. If they don't work out for you, go to the next cheapest.
I've been programming routers in custom cabinet shops for nearly 20 years. If you want to send me your design, I may be able to give you some ideas.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
24-10-2014 #5
Hi, thanks for the comments. jimbo_cnc I am base in North East London at the moment. As a lot of manufactures are based out of the city to keep their costs down I don't think that it will really matter where the CNC service provider is based as they will probably use a courier unless it is a huge amount of part you need cut. For pricing I have been sending all the parts off for a fairly standard base unit 600mm wide, a top and bottom, 2 sides, a back, and 2 battens for the back to fix to. The parts also have some holes for fixing through and shelf holes etc so no complex shapes or 3D work. £80 for a carcass seems reasonable, what type of carcass is that and what material? There is the advantage with Timbmet that they are a big supplier of panel products so will have what material you want to use to hand. Can I ask what they are charging you for delivery and the cost of the material? Thanks
25-10-2014 #6
24-10-2014 #7
Hi Gerry. Thanks for your reply. I'd be happy to send you a dxf file of the sort of parts that I'd like to have cut, that is very kind of you to offer some advice. I do think that a lot of businesses don't like bothering with small orders from companies that are trying to get up and running so take a punt and put their prices high, it is a shame as everyone has got to start somewhere.
Have you got an email address I can send a dxf file to?
Thanks again.
Phil
25-10-2014 #8
cncwoodworker at comcast dot net
Gerry
25-10-2014 #9
I set up one of my current activities based on outsourcing as many parts as possible, in stainless steel sheet and various plastics.
I also do limited numbers and two to three years in I realised that a small cnc might help me.
In the end it turned out to work better if I tried to make as many parts myself as I could.
I think that if you want to do custom work, having your own cnc is very useful.
If you need to start by outsourcing, which is a good idea, even if doing parts yourself is "better" in the long run, the supplier needs to be flexible too. That probably means that they are focusted on small batches too.
Mixing small batches with very big ones is often hard, unless the business actually focuses on being able to handle both.
Having a local one may be very good. Being able to just pop over to discuss stuff makes stuff much easier.
I think price will come from how much hassle you take out of the job.
If you can send nested cad files or even coded files to the cnc guy that only need cutting, it would be a lot cheaper than sending each individual part file over, adding quantity, thickness.
25-10-2014 #10
If I were doing the work, I would not want nested files or machine code. My machine runs the way I want it to run, not the way my customer thinks it should run. If you want to outsource to me, then you have to pay me to program your parts. You'd need a very good working relationship imo to be able to send someone g-code to run for you.
I think that outsourcing is probably much more cost effective with larger jobs, rather than small one off jobs. Both large and small jobs often require a similar amount of programming and setup time, and on larger jobs that cost is spread out among more parts, making them cheaper.Gerry
Question on PCB and routing
By Fivetide in forum General ElectronicsReplies: 20Last Post: 12-05-2013, 06:35 PM -
routing aluminium help :)
By don_jarr in forum Metalwork DiscussionReplies: 18Last Post: 27-11-2012, 09:05 PM -
NEW MEMBER: New to cnc routing and looking to buy a machine.
By stamper in forum New Member IntroductionsReplies: 3Last Post: 03-12-2011, 03:31 PM -
BUILD LOG: routing 3d?
By proddy in forum DIY Router Build LogsReplies: 2Last Post: 03-08-2009, 11:20 PM
