    cncwoodworker at comcast dot net
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Sven's Avatar
    Lives in a, Netherlands. Last Activity: 07-05-2020 Has been a member for 9-10 years. Has a total post count of 46. Received thanks 4 times, giving thanks to others 0 times.
    I set up one of my current activities based on outsourcing as many parts as possible, in stainless steel sheet and various plastics.
    I also do limited numbers and two to three years in I realised that a small cnc might help me.
    In the end it turned out to work better if I tried to make as many parts myself as I could.
    I think that if you want to do custom work, having your own cnc is very useful.
    If you need to start by outsourcing, which is a good idea, even if doing parts yourself is "better" in the long run, the supplier needs to be flexible too. That probably means that they are focusted on small batches too.
    Mixing small batches with very big ones is often hard, unless the business actually focuses on being able to handle both.
    Having a local one may be very good. Being able to just pop over to discuss stuff makes stuff much easier.
    I think price will come from how much hassle you take out of the job.
    If you can send nested cad files or even coded files to the cnc guy that only need cutting, it would be a lot cheaper than sending each individual part file over, adding quantity, thickness.
    Quote Originally Posted by Sven View Post
    If I were doing the work, I would not want nested files or machine code. My machine runs the way I want it to run, not the way my customer thinks it should run. If you want to outsource to me, then you have to pay me to program your parts. You'd need a very good working relationship imo to be able to send someone g-code to run for you.
    I think that outsourcing is probably much more cost effective with larger jobs, rather than small one off jobs. Both large and small jobs often require a similar amount of programming and setup time, and on larger jobs that cost is spread out among more parts, making them cheaper.
    Gerry
  1. Question on PCB and routing
    By Fivetide in forum General Electronics
    Last Post: 12-05-2013, 06:35 PM
  2. routing aluminium help :)
    By don_jarr in forum Metalwork Discussion
    Last Post: 27-11-2012, 09:05 PM
  3. NEW MEMBER: New to cnc routing and looking to buy a machine.
    By stamper in forum New Member Introductions
    Last Post: 03-12-2011, 03:31 PM
  4. BUILD LOG: routing 3d?
    By proddy in forum DIY Router Build Logs
    Last Post: 03-08-2009, 11:20 PM
