    I have a plywood product im thinking about producing on my router. It incorperates a bungee cord that acts as a preload spring.
    I need to join 3mm elastic shock cord into a loop to make the part. Would rather not simply tie them together as its hard to get the lengths consistant and it looks a little messy.
    These crimps look quite good, I contacted the seller in regards to which type of crimping pliers would work for this, but they are taking their time to reply. I can't find anything similer in the UK. What would you guys do to join bungee cord in neat loop?
    Here is the link to the crimps
    https://www.etsy.com/uk/listing/1555...ver?ref=market
    Gav
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    Best would be if you join then via small hot melt casting. The way a USB or 3mm jack cable ends. You can use good high temp heat glue gun/190-220C/, make small 2 piece aluminum mold and inject the hot melt - Polyamide Sticks - TEC Bond 7718 , thats what i use.
    Dont forget to leave small air escape hole/0.5mm or similar/ and use 2 pins to center the mold. Or maybe not, the air will escape through the bungee cord
    I have done that and works, i have cast things as big as wheel over 2 skate bearings using 80W gun. You will find a good ~200w gun extremely easy to work with
    There are other sizes, you have to calculate if its worth but 12mm works ok for small details. Otherwise i would jump to bulk melt gun
    Guns 12mm :
    https://www.gluegunsdirect.com/shop/...12mm-glue-guns
    Glue 12mm:
    https://www.gluegunsdirect.com/shop/...ecbond-7718-12
    PS:
    or sth like these:
    http://www.aliexpress.com/item/Whole...111629169.html
    http://www.ebay.co.uk/itm/Blind-cord...58665590&rt=nc
    Lives in Plymouth, United Kingdom. Last Activity: 14 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    Those crimps look like a cheap, neat, way to do it. I'd be surprised if you couldn't do the job with a big pair of pliers, or for a posher job drill a hole in a bit of steel, slit it down the middle, and clamp in vice as an improvised press. Look for a "proper" tool if the prototypes work out well!
  1. Joining or "but joining" linear rails
    By CNCBlug in forum Rails, Guideways & Bearings
    Last Post: 09-10-2014, 08:56 AM
  2. T and L profile Joining plates
    Last Post: 02-01-2013, 08:58 PM
  3. NEW MEMBER: Finally got round to joining the best CNC group on the net!!!
    By g4ghp in forum New Member Introductions
    Last Post: 19-03-2012, 07:31 PM
  4. NEW MEMBER: Hello Im interested in joining you all
    By Guisborough in forum New Member Introductions
    Last Post: 18-08-2010, 11:01 PM
  5. NEW MEMBER: Joining the "ship"
    By Ali Kat in forum New Member Introductions
    Last Post: 13-08-2007, 08:49 AM
