Now that's nice!! I like that idea ... off to do some research ...
Tim G-C
“I disapprove of what you say, but I will defend to the death your right to say it.”
(attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
15-10-2014 #2
If you are happy to make your models in two halves, surely a three axis machine could do most of this? G,
16-10-2014 #3
The horse is constructed using a series of ever decreasing 'slices' which are joined and then carved. Yes I could easily join two halves and finish the 'inside' where a 3 Axis system cannot reach by hand. Initially, what I am after is to digitise the templates I have, to enable me to better 'Nest' the parts and cut them out saving me considerable time (and materials). If I can scan a completed 'half' then the router could do it providing there is sufficient Z travel and the Z assembly is kept to a minimum size to clear the 'curves of the body.
Tim G-C
16-10-2014 #4
I use Vectric V Carve Pro to design shapes and other stuff in MDF or wood. Usually 2d, but your suggestion of laminating to create a 3d result and then hand finishing would be achievable.
If you were to scan or make a photograph of one of your existing templates you can pull it in to V Carve and using the trace feature you can then make the "Picture" into a new template of any size. Turning that "Shape" outline into vectors for editing is a one click process. (Exportable as a DXF file if you need anyone else to machine it)
Once saved at the dimensions you require it would be easy to make smaller copies using the copy and paste function, then resize using the object size function.
Once you have decided how many to copy the next function would nest them onto the sheet represented in the software.
Obviously readjusting a few vectors where required would be necessary for the various sizes and this will take a little time. But once they are made the cutting out will be a breeze and every time identical.
Have a look at http://forum.vectric.com/ and see if anyone on there has done similar. Very helpful people and the software is a doddle to use and very comprehensiveIf you can't fix it with a hammer you've got an electrical problem !
16-10-2014 #5
You can also use the open source free software Inkscape to trace an image and output to dxf.
16-10-2014 #6
Agree with Geoffrey if you can half the finished horse then with a digitising probe you could create a point cloud and mesh together for the finished horse why bother with templates at all.? Then just let the CNC machine do the work.
Even if half is too much Z height for probing or cutting you could slice into managable sizes and probe the edges then piece together very easy.
Can you show a picture of the Templates your talking about.!
16-10-2014 #7
Ive used an xbox 360 kinect camera to scan 3d objects with good results then used slicer ( i think its called to slice it into pieces to carve
Clamping nut - ER11 collet... am I being thick?...
By Doddy in forum Tool & Tooling TechnologyReplies: 2Last Post: 31-01-2014, 07:05 PM -
RFQ: x4pcs 18mm Marine Ply Disc's - Ruff & Ready @ 390mm OD
By Lee Roberts in forum Projects, Jobs & RequestsReplies: 14Last Post: 29-03-2013, 06:39 PM -
Step clamp design - Hold down thin or irregular shaped objects while milling!
By Lee Roberts in forum Programmers CornerReplies: 5Last Post: 15-04-2012, 12:36 PM -
NEW MEMBER: I am new and havent a clue
By dip in forum New Member IntroductionsReplies: 1Last Post: 02-09-2010, 10:25 PM -
By Jonny in forum New Member IntroductionsReplies: 6Last Post: 02-09-2010, 07:33 PM
