    I don't think that lasers are much good for anything other than engraving and profiling. My solution to your "slot" problem would be to laminate a 3mm ply back onto a 6mm slotted front. G.
    Rebating would be extreamly time consuming and wastefull with a laser.
    You would need to engrave a rebate which means rastering back and forward stepping over maybe 0.1mm at a time. The quailty would also suck and you would need to refocus the laser as you eat into the wood.
    If this is a big production run have you thought about multiple machines maybe a laser to profile and then a router to rebate. you could even use a hand router. This is something I am considering for a product im making right now, sometimes its worth thinking about old techiniques rather than just thinking how can I do this with a cnc be it laser or router.
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
  1. Wood suppliers
    By Danielroyal25 in forum Woodwork Discussion
    Last Post: 24-07-2014, 10:28 PM
  2. BUILD LOG: Wood Router
    By Buba b in forum DIY Router Build Logs
    Last Post: 03-10-2012, 09:49 AM
  3. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
  4. Laser marking wood
    By artmin in forum Computer Software
    Last Post: 17-02-2012, 05:58 PM
  5. NEW MEMBER: Wood Lathe - fitments
    By Musochasle in forum New Member Introductions
    Last Post: 10-08-2010, 08:28 AM
