Thread: CNC Lathe Build. Hopefully.
Frankly I would start with one of the small Sieg lathes, also sold under other names, rather than try to make your own if you don't already have a lathe. But not too small. You get a reasonably accurate bed, spindle and slides as well as the motor drive. Backlash is not nearly so critical in a lathe so you can live with the normal feed screws though ballscrews are nice to have. It is easy to underestimate the rigidity you need for a lathe as well as the fit of the slides if you want to turn anything metal. Lathes are the essential machine tool.
03-01-2015 #2
Agree, as long as the part is small enough a sliding table mounted vertically on the cross-slide allows you to mill things. It's what I did before I got a mill. For simple stuff you don't even need a table, a right-angle mount will do, tedious to move workpiece manually but doable
03-01-2015 #3
Hi Guys
The intention of my post was just to highlight the use of concrete as a solid base for construction not to construct the lathe shown. a couple of lengths of 25mm square steel bar and a small quantity of rebar and a simple box mould would give you a solid base on which to mount a couple of Hiwin Rails.
I have seen on superb gantry mill manufactured this way(sorry can't find the link) but this is something similar.
https://www.youtube.com/watch?v=fDiEi2bOXgs
Regards
MikeLast edited by mekanik; 03-01-2015 at 12:11 PM.
03-01-2015 #4
Yeah concreet was very popular during ww2 for lathes and mills and some boats, its the diy lathe thing if funny because of the availability of lathes for cheeps that already have nice ways and alignment and all that stuff. E.g. The boxford plain lathe for £350 that would make an awsome base for cnc lathe and tey can be got for even less if you hunt arround a bit.
although making your own tools is an amazing way of learning a lot about the way they get made and what makes them good or bad.
no offence ment prommis,
Stuart
03-01-2015 #5
I agree Stu
But seemed like Wal just wanted to build something a bit different.
Mike
03-01-2015 #6
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM -
Thoughts on a future lathe build, CL430 as a base
By m_c in forum Clarke LathesReplies: 2Last Post: 22-10-2011, 12:38 PM -
My lathe, and possible new build
By jpcnc in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 23-04-2011, 08:20 AM -
RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
By Chas in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2010, 09:28 AM
