20-05-2009 #6
OK, I'm no expert on Mach3 but I can write VBScript! This script appears to use an external probe and an external DRO - I'm assuming you have those and that they work and that you have elsewhere verified you can retrieve the DRO values . If thats not the case then this isnt going to work ever.
Assuming the above, the only lines that need to be changed are where it subtracts and adds 3 to the current values of X and Y, if Mach3 is set for metric I would assume these should be 75 (for 75mm), e.g.
Code:XNew = Xcurrent - 3 'probe 3 inches to left
Code:XNew = Xcurrent - 75 'probe 75mm to left
The new probe and finding the center of a hole
By Ricardoco in forum Probing, Digitizing & ScaningReplies: 9Last Post: 13-11-2015, 06:43 AM -
Help with Mach3 inputs and VB script ?
By EddyCurrent in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 27-11-2013, 06:35 PM -
Mach 3 tool setter Big-tex version / script help please
By dudz in forum Probing, Digitizing & ScaningReplies: 0Last Post: 25-06-2013, 08:01 PM -
Finding pictures and viewing the albums of a member ?
By WandrinAndy in forum General DiscussionReplies: 3Last Post: 16-10-2012, 03:29 PM -
Edge Finding For Newbies
By M250cnc in forum CAD & CAM SoftwareReplies: 14Last Post: 01-03-2011, 10:55 AM
