Page 1 of 3 123 LastLast
    Hey guys,
    I normally have a good friend of mine building my control boxes so ive never had the chance to see how its done. my question is to you good guys how the hell do i wire these things up, or more importantly can you explain the diagram for me?
    Could someone please explain the attached image please so i can try crack this once and for all ..
    Driver : PM452
    Motor : Plantry gearbox with CNC4you - 60BYGH301B
    Please guys before you sit back in your chair and snigger about my question please consider we were all here at one point - maybe some of us more clued up than others
    Hey d-man, those curly bits are the windings of the stepper motor. So from your pic you would join the YEL and BLU together and the ORG and BRN. Then run the remaining 4 to your stepper driver.
    I'm sure someone who has a clue what they are talking about will be along shortly with better info so best you wait for them!
    Jim
  3. The Following User Says Thank You to cncJim For This Useful Post:
    Ah that does make sense! cheers pal!
    however my current setup runs 4 pins and this one will work out as 6, or are you saying that the joined wires dont go to anything which would result in 4 pins :)
  5. #4
    Are you sure you want to use that way to connect the motor ? that's a series connection, most would recommend the parallel connection.
    A+ Red
    A- Black
    B+ White
    B- Green
    Yellow & Blue, connected together but going nowhere, just insulate once joined.
    Orange & Brown, connected together but going nowhere, just insulate once joined.
  6. #5
    Well it was just to try get my head around it Eddie, then i looked at the parallel connection and started to smell smoke (From my brain!) Parallel connection here http://prntscr.com/4wyek3
    Cheers for that Eddie appreciate it
  7. #6
    Ok so, going for the parallel connection am i right in saying...
    A+ - Red/Blue
    A- - Yellow/Black
    B+ - White/Brown
    B- - Orange/Brown
    My head hurts this early
  8. #7
    Parallel connections
    A+ Red & Blue joined together
    A- Yellow & Black joined together
    B+ White & Brown joined together
    B- Orange & Green joined together
    Edit: Ha ha you just beat me to it but you got B- wrong (typing too fast likely)
  9. The Following User Says Thank You to EddyCurrent For This Useful Post:
  10. #8
    Thats it im now a "pro" haha cheers boys appreciate it! time to wire this baby up
  11. #9
    Crap ran into another stickler...
    Im using the MSD542 drivers with the Nema 23 SY60
    Motor diagram looks like this...
    However the Driver datasheed does not give colour codes http://www.motioncontrolproducts.com...ing-driver.pdf
    I have the wires joined, its just getting the 4 coupled wires into the A+ A- & B+ B- if you know what i mean.. how do you determine what double wire is for where
  12. #10
    A+ yellow/white & red
    A- yellow & red/white
    B+ green/white & black
    B- green & black/white
    see diagram on page 7 for parallel 8 wire connection
    http://www.leadshine.com/UploadFile/Down/AM882m.pdf
  1. Stepper motor tunning wiring
    By handyoodman03 in forum Stepper & Servo Motors
    Last Post: 11-01-2013, 05:49 PM
  2. Newbie Initial Wiring/Setup
    By Rikk in forum Motor Drivers & Controllers
    Last Post: 28-06-2011, 10:19 AM
  3. Stepper motor wiring
    By Buba b in forum Stepper & Servo Motors
    Last Post: 28-03-2010, 06:16 PM
  4. Stepper Motor Wiring (Screened?)
    By pequod in forum Stepper & Servo Motors
    Last Post: 03-08-2009, 10:15 AM
  5. Motor / drive wiring problem: help!
    By lateAtNight in forum General Electronics
    Last Post: 29-04-2009, 07:40 PM
