    A+ yellow/white & red
    A- yellow & red/white
    B+ green/white & black
    B- green & black/white
    see diagram on page 7 for parallel 8 wire connection
    http://www.leadshine.com/UploadFile/Down/AM882m.pdf
    cheers does it matter if its not a Leadshine?
    No, it was just a diagram I knew about, it's the motor drawing that matters.
  4. The Following User Says Thank You to EddyCurrent For This Useful Post:
  5. #4
    OK guys another one im needing help with... i have another SY60STH86/3008BF - however the wire colours are different but on zapps website datasheet
    The wires on my motor are as follows
    red
    blue
    black
    green
    blue/white
    black/white
    red/white
    green/white
    sure this is just done to confuse the hell out of me haha
  6. #5
    OK so maybe not so bad as i thought.. only the Blue & Blue/White is different. will call this the "Yellow" wire :)
    So is this correct:
    A+ yellow/white & yellow (but its blue!)
    A- Red/White & Red
    B+ Green/White & Green
    B- Black/White & Black
  7. #6
    Using the standard diagram;
    For any colour scheme with parallel connections use this; (I've just used -A etc. to represent A with a bar on top (not A))
    A+ (A to -C )
    A- (-A to C )
    B+ (B to -D)
    B- (-B to D)
  8. The Following User Says Thank You to EddyCurrent For This Useful Post:
  9. #7
    Nice one buddy thanks
  10. #8
    A+ (A to -C )
    A- (-A to C )
    B+ (B to -D)
    B- (-B to D)
    Im really struggling to get this around my head, i think i have read it so many times i have confused myself (i need to swap from series to parallel as i didn't realise first time round)
    which pairs do i join to each other and which pairs to i wire to the terminals?
    many thanks
  11. #9
    Using the diagram above
    Parallel
    A+ (Yellow/White to Red)
    A- (Yellow to Red/White)
    B+ (Green/White to Black)
    B- (Green to Black/White)
    Series
    A+ (Yellow/White)
    A- (Red/White)
    B+ (Green/White)
    B- (Black/White)
    (Yellow to Red) not connected to any terminal, just connect together and insulate.
    (Green to Black)not connected to any terminal, just connect together and insulate.
  12. #10
    Ok so when in parallel you pair the 8 wires (4pairs)accordingly and then they would go strait to the terminals on the driver were as in series you just have 4 of them paired (2pairs) and the other 4 go to the driver?
    Many thanks
  1. Stepper motor tunning wiring
    By handyoodman03 in forum Stepper & Servo Motors
    Last Post: 11-01-2013, 05:49 PM
  2. Newbie Initial Wiring/Setup
    By Rikk in forum Motor Drivers & Controllers
    Last Post: 28-06-2011, 10:19 AM
  3. Stepper motor wiring
    By Buba b in forum Stepper & Servo Motors
    Last Post: 28-03-2010, 06:16 PM
  4. Stepper Motor Wiring (Screened?)
    By pequod in forum Stepper & Servo Motors
    Last Post: 03-08-2009, 10:15 AM
  5. Motor / drive wiring problem: help!
    By lateAtNight in forum General Electronics
    Last Post: 29-04-2009, 07:40 PM
