Thread: Wiring a motor - as a newbie!
OK so maybe not so bad as i thought.. only the Blue & Blue/White is different. will call this the "Yellow" wire :)
So is this correct:
A+ yellow/white & yellow (but its blue!)
A- Red/White & Red
B+ Green/White & Green
B- Black/White & BlackLast edited by D-man; 23-10-2014 at 10:54 AM.
23-10-2014 #2
The Following User Says Thank You to EddyCurrent For This Useful Post:
23-10-2014 #3
Nice one buddy thanks
24-10-2014 #4
Im really struggling to get this around my head, i think i have read it so many times i have confused myself (i need to swap from series to parallel as i didn't realise first time round)
which pairs do i join to each other and which pairs to i wire to the terminals?
many thanks
24-10-2014 #5
Using the diagram above
Parallel
A+ (Yellow/White to Red)
A- (Yellow to Red/White)
B+ (Green/White to Black)
B- (Green to Black/White)
Series
A+ (Yellow/White)
A- (Red/White)
B+ (Green/White)
B- (Black/White)
(Yellow to Red) not connected to any terminal, just connect together and insulate.
(Green to Black)not connected to any terminal, just connect together and insulate.Last edited by EddyCurrent; 24-10-2014 at 12:45 PM.
24-10-2014 #6
Ok so when in parallel you pair the 8 wires (4pairs)accordingly and then they would go strait to the terminals on the driver were as in series you just have 4 of them paired (2pairs) and the other 4 go to the driver?
Many thanks
24-10-2014 #7
Yes that's right
24-10-2014 #8
Many thanks indeed not sure why I got so confused I have attached a picture of it hopefully done correctly
Stepper motor tunning wiring
By handyoodman03 in forum Stepper & Servo MotorsReplies: 47Last Post: 11-01-2013, 05:49 PM -
Newbie Initial Wiring/Setup
By Rikk in forum Motor Drivers & ControllersReplies: 3Last Post: 28-06-2011, 10:19 AM -
Stepper motor wiring
By Buba b in forum Stepper & Servo MotorsReplies: 5Last Post: 28-03-2010, 06:16 PM -
Stepper Motor Wiring (Screened?)
By pequod in forum Stepper & Servo MotorsReplies: 19Last Post: 03-08-2009, 10:15 AM -
Motor / drive wiring problem: help!
By lateAtNight in forum General ElectronicsReplies: 2Last Post: 29-04-2009, 07:40 PM
