    Parallel connections
    A+ Red & Blue joined together
    A- Yellow & Black joined together
    B+ White & Brown joined together
    B- Orange & Green joined together
    Edit: Ha ha you just beat me to it but you got B- wrong (typing too fast likely)
  2. The Following User Says Thank You to EddyCurrent For This Useful Post:
  3. #2
    Thats it im now a "pro" haha cheers boys appreciate it! time to wire this baby up
    Crap ran into another stickler...
    Im using the MSD542 drivers with the Nema 23 SY60
    Motor diagram looks like this...
    However the Driver datasheed does not give colour codes http://www.motioncontrolproducts.com...ing-driver.pdf
    I have the wires joined, its just getting the 4 coupled wires into the A+ A- & B+ B- if you know what i mean.. how do you determine what double wire is for where
  5. #4
    A+ yellow/white & red
    A- yellow & red/white
    B+ green/white & black
    B- green & black/white
    see diagram on page 7 for parallel 8 wire connection
    http://www.leadshine.com/UploadFile/Down/AM882m.pdf
  6. #5
    cheers does it matter if its not a Leadshine?
  7. #6
    No, it was just a diagram I knew about, it's the motor drawing that matters.
  8. The Following User Says Thank You to EddyCurrent For This Useful Post:
  9. #7
    OK guys another one im needing help with... i have another SY60STH86/3008BF - however the wire colours are different but on zapps website datasheet
    The wires on my motor are as follows
    red
    blue
    black
    green
    blue/white
    black/white
    red/white
    green/white
    sure this is just done to confuse the hell out of me haha
  10. #8
    OK so maybe not so bad as i thought.. only the Blue & Blue/White is different. will call this the "Yellow" wire :)
    So is this correct:
    A+ yellow/white & yellow (but its blue!)
    A- Red/White & Red
    B+ Green/White & Green
    B- Black/White & Black
  11. #9
    Using the standard diagram;
    For any colour scheme with parallel connections use this; (I've just used -A etc. to represent A with a bar on top (not A))
    A+ (A to -C )
    A- (-A to C )
    B+ (B to -D)
    B- (-B to D)
  12. The Following User Says Thank You to EddyCurrent For This Useful Post:
  1. Stepper motor tunning wiring
    By handyoodman03 in forum Stepper & Servo Motors
    Last Post: 11-01-2013, 05:49 PM
  2. Newbie Initial Wiring/Setup
    By Rikk in forum Motor Drivers & Controllers
    Last Post: 28-06-2011, 10:19 AM
  3. Stepper motor wiring
    By Buba b in forum Stepper & Servo Motors
    Last Post: 28-03-2010, 06:16 PM
  4. Stepper Motor Wiring (Screened?)
    By pequod in forum Stepper & Servo Motors
    Last Post: 03-08-2009, 10:15 AM
  5. Motor / drive wiring problem: help!
    By lateAtNight in forum General Electronics
    Last Post: 29-04-2009, 07:40 PM
