    Im slightly new to the CNC world. This may be a normal situation but can anyone help me.
    Ive got a basic 540 cnc router. Link for is http://en.step-four.at/hp2/index.php?action=1482
    The problem i'm having is that when i increase the speeds of the motors, my motors dont run smoothly across the axis, this is for the Y and X axis. This is on Mach3 and i specifically increase the velocity. Below 100 in/min it runs smoothly. above that it appears as if the motor is becoming jammed on the way but it is going faster. Is this normal for this type of router?
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Skydeals View Post
    The way I read this and the specs is that the machine is only capable of 78"/min and you are saying it runs ok at 100"/min which is better than the spec of the machine. Unless I am missing something. ..Clive
    The spec says it can do;
    "positioning speed 2000 mm/min"
    so as you quoted inches that's 78.7 in/min
    That's why it works below 100 in/min.
    Edit: Ha ha it happens all the time, posted same time as Clive S
  5. The Following User Says Thank You to EddyCurrent For This Useful Post:
  6. #4
    ahh. I didnt carefully read that webpage to find what speed it can do. So ill stick to 78in/min at the most.
    thanks for the prompt response
  1. The ideal CNC machine for my (basic)needs?
    By mark84 in forum Machine Discussion
    Last Post: 12-03-2014, 10:56 AM
  2. NEW MEMBER: Basic 3d milling
    By proddy in forum New Member Introductions
    Last Post: 08-06-2012, 12:11 AM
  3. Advice on some basic tools
    By GTJim in forum General Discussion
    Last Post: 22-09-2011, 12:16 PM
  4. Which Basic Lathe
    By graysclassics in forum Milling Machines, Builds & Conversions
    Last Post: 06-07-2011, 10:39 PM
  5. G-Code into stepper driver pulses?
    By HankMcSpank in forum Computer Software
    Last Post: 09-01-2010, 12:55 PM
