    Hi Guys, looking for a little help on this one, may possibly be a falt with the BOB i dunno...
    OK i have to motors running on the X. When I try to Home, only one switch works, obviously because one switch is not lit. (Its wired properly as ive swapped it out and put in in another input and works fine)
    I just cant seem to get this thing actve, Ive activated it in P&P & Home/Soft Limits.
    Setup is as follows:
    Z - IN 1
    Y - IN 2
    X1 - IN 3
    X2 - IN 4 (Which is all activated, but will still not come to life)
    Running on a uniport
    What do you mean by "Input 1"? You don't assign home switches to inputs?
    Go to General Config and uncheck "Home Slave with Master".
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Hi Gerry,
    Really? are the ones in the picture only for Limit switches?
    I have unchecked "Home slave with master"
    That remionds me, is there a way to recover my screenset from you. i bought it a while back and since lost and upgraded my pc.
    I thought you were referring to input 1 in Mach3, not on your board.
    Does it work with "Home Slave with Master" unchecked?
    Send me an email and I'll resend the screenset to you.
    Gerry
    Are the home switches normally open (NO) or normally closed (NC) ?
    If NC you wire the X,Y,Z in series then into one input of the bob, then A (the slaved X) into another input of the bob
    If NO you wire them in parrallel then into one input of the bob, then A (the slaved X) into another input of the bob
    You can see how my NO inductive proximity switches are connected here (bottom left corner);
    http://www.mycncuk.com/threads/6565-...7622#post57622
    Thanks Gerry, would you like me to send it from the one i would of used with Paypal to prove i have purchased it?
    Yeah the motors all work as they should. its only when it comes to homing and that home switch not being active or whatever reason
    oh i didnt go that far buddy... i just put each one on their own input in the bob.
    i dont understand it every other switch works bar this one on the A axis
  1. engineers square - recommendations
    By dsc in forum Marketplace Discussion
    Last Post: 09-06-2013, 08:13 PM
  2. WANTED: Head Tram Square
    By dudz in forum Items Wanted
    Last Post: 31-03-2013, 01:03 PM
  3. Square Ballnut??
    By Ricardoco in forum Gantry/Router Machines & Building
    Last Post: 29-06-2012, 10:32 PM
  4. WANTED: 10mm think square of aluminium?
    By Tenson in forum Items Wanted
    Last Post: 08-06-2012, 12:42 PM
  5. Getting everything square
    By daveshorts in forum Gantry/Router Machines & Building
    Last Post: 31-01-2010, 11:21 AM
