    Maybe someone out there has had experience trying this already but I am currently pondering what is the best way to run 2 x 16mm ballscrews to move my flying gantry on my machine, still at the design stage so any modifications needed would be much easier at this stage.
    What would work best out of the 3 configurations below and what would not work and why...!
    Option 1 - 2 x 23 Steppers running each screw independently off of the same driver card
    Option 2 - 2 x 23 Steppers running each screw as above but also a toothed belt linking the two together to prevent misalignment
    Option 3 - 1 x 23 Stepper (or maybe larger) running on one screw with the two screws linked with a belt.
    If linking them with a belt then how do you go about getting the right length belt or do I adjust my design to suit a standard belt??
    Can't really comment on this as i have never built a twin screw machine but 4th option is single screw placed central under the bed.
    If using option 3 you use an idler pulley to adjust tension.
    John S -
    Steve, take a look at this: [ame="http://www.mycncuk.com/forums/showthread.php?t=786"]Link[/ame]
    Look for post [ame="http://www.mycncuk.com/forums/showpost.php?p=4282&postcount=9"]#9[/ame] by HS93, i'v been asking belt related questions as well, you can use that to work out what size belts you need.
    I'v not seen anyone use two leadscrews on the X Axis befor, its normally the Y Axis they do it on to stop "racking", do you really need two?
    If you could submit some of your design for us to look at it may help with ideas.
    I may be calling my X axis my Y and visa versa! What i am calling my X axis runs along the table and my Y axis runs on the gantry, just seemed to make more sense this way round! Yes using the 2 leadscrews is to prevent racking.
    Just in the middle of tweaking the design now but I will post some pics later. But the basic configuration is a typical flying gantry machine with two lead screws / ball screws to drive the gantry, this is why i was asking about belt configurations to prevent racking.
    Steve, take a look at this: Link
    Look for post #9 by HS93, i'v been asking belt related questions as well, you can use that to work out what size belts you need.
    Well you have just answered all my questions on sizing belts and pulleys! Nice one Lee.
    Just need to figure out what configuration will work best, may build into my design the option to try them all and see how it works.
    Just one other thing, you look way to serious in that avatar photo to the point were you are scaring my kids! Ever felt the urge to become an axe murderer???
    Quote Originally Posted by HiltonSteve View Post
    Your welcome mate, i'v added those posts to the FAQ section for later use if you ever need to go looking for them.
    Indeed, ill keep an eye out for your findings.
    Well you could be right i always thout it was that way around, looking at google images it seem i'm wrong and your right Steve:
    or do we filp the 0,0,0 on its axis so we are now looking down the z axis, the pro's will have to confirm because now im :confused:.
    End of the day if your building a machine then you decide which way round you want your X and Y, does it really matter??
    All the CNC stuff I have worked on always had the longest travel movement on the bed as the X. So if your gantry was wider than your machine is long (don't really know why you would do this!) then maybe I would be calling my gantry X then you would be right!
    Well that sounds about right, i think ? lol, this is for you mate anyway: .
    Drew a part up the other day and sorted a long thin bit of spare material out it would just fit on and put it on the router with a lump sticking out.
    Loaded the program and realised I had drawn it 90 degrees to how the material lay so X needed to be Y and visa versa.
    Went into Mach and swapped the pins over in ports and pins, cut the job and then swapped it back.
    John S -
  1. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
  2. Ball screw
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 20-10-2011, 01:28 PM
  3. Ball screw mounting questions
    By Redccm in forum Lead Screws, Nuts & Supports
    Last Post: 28-01-2011, 09:29 PM
  4. WANTED: 12mm ball screw & nut
    By phill05 in forum Items Wanted
    Last Post: 22-06-2010, 09:26 PM
  5. Stationary Ball Screw
    By Wobblybootie in forum Lead Screws, Nuts & Supports
    Last Post: 29-12-2009, 01:12 PM
