20-05-2009 #3
Steve, take a look at this: [ame="http://www.mycncuk.com/forums/showthread.php?t=786"]Link[/ame]
Look for post [ame="http://www.mycncuk.com/forums/showpost.php?p=4282&postcount=9"]#9[/ame] by HS93, i'v been asking belt related questions as well, you can use that to work out what size belts you need.
I'v not seen anyone use two leadscrews on the X Axis befor, its normally the Y Axis they do it on to stop "racking", do you really need two?
If you could submit some of your design for us to look at it may help with ideas.
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
Ball screw mounting questions
By Redccm in forum Lead Screws, Nuts & SupportsReplies: 3Last Post: 28-01-2011, 09:29 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM -
Stationary Ball Screw
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 14Last Post: 29-12-2009, 01:12 PM
