Thread: RS 232 to USB cable driver
Keep reading through this thread; this was for AM882's don't know if it fully applies to your drives.
http://www.mycncuk.com/threads/5302-...7463#post57463Last edited by EddyCurrent; 20-10-2014 at 06:27 PM.
20-10-2014 #2
i dont think i have got that far successfully yet i got to the stage were its asking me to select a com port but then i found from zap that i dont have it set up, that is when i was trying to get the driver directed to it and but i couldn't find the driver file. Sorry Im in pretty far in over my depth with this hole pc thing so its being a very steep and slow learning curve. Will all so add that the drivers are all set up with auto tune but i think they could be better still which is why i want to get pro tune working.
many thanks
20-10-2014 #3
So from here; http://www.leadshine.com/productdeta...EM&model=EM806
you downloaded these ?
ProTuner for the EM Series Stepper
EM_Series_sm.pdf
You got Protuner software installed on the PC
You've plugged the special cable between the PC and the EM806 and started the Protuner software, it's asking for a COM port ?
There's a way in Device Manager to see which is the right port but another way is to keep trying different ports until it connects, so start at COM 2, then COM3, etc. until it connects.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
20-10-2014 #4
thats correct i downloaded the driver for the cable from the page on zapp.
i have tried 1-12 com ports and they all came up with a error ( i forget what it was but can go out later a take a look again) it was at this point i spoke with zapp and they said go to cheque something else to i think get the com port talking to the cable driver but i will have to go see if i can find what that was, when i did this i had to look for the driver file but i couldn't find it were it should be so assume it was not the correct one possibly?
20-10-2014 #5
Right, it's all coming back to me now, if you look at the second picture down here; http://www.mycncuk.com/threads/5302-...7475#post57475
it shows how to check the cable driver is installed and shows you the COM port it's at. As you say this needs to be working first.
Is this the driver ?
http://www.zappautomation.co.uk/usb-...db9-cable.html
I downloaded it, it's a rar file so you need to unpack the archive into a new folder. Once unpacked run the autorun.exe and when the dialogue appears select 'Manual', read the section for whatever version of operating system you have. You should now be able to select the correct driver and install it (it was all in English)
If you have nothing to unpack the archive, I used this; http://www.7-zip.org/
or there's this too; http://download.cnet.com/RarZilla-Fr...-10647724.htmlLast edited by EddyCurrent; 20-10-2014 at 09:47 PM.
20-10-2014 #6
yes thats right it was that page i was looking at and then i went into it to to try and load the driver and yes that is the one i used. The cable did come with a cd but to much was in chinese(literally) to understand what i needed to do.
many thanks for the help
21-10-2014 #7
i think im making some progress i have un rard the file and have done the auto run selected the windows 7 version then the i386 folder then i get lost there is a list that comes up with things like ftbusui.dll and ftser2k.sys and not sure what i need to chose? there is one described as usb serial property page provider?
There was a install manual but it doesn't seam to be relevant to the auto run?
CY cable terminals
By kingcreaky in forum Marketplace DiscussionReplies: 15Last Post: 26-03-2014, 08:24 AM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Cable Size ?
By manofgresley in forum General ElectronicsReplies: 1Last Post: 09-05-2013, 02:55 PM -
cable prices
By deannos in forum Marketplace DiscussionReplies: 15Last Post: 10-12-2012, 10:25 PM -
WANTED: Looking for cable braid
By Smiler in forum Items WantedReplies: 8Last Post: 30-05-2009, 06:14 PM
