Hi
I have a small desktop cnc - Chinese cnc 3040 - and i want to attach a small flexible vacuum hose as a dust collector to the spindle assembly.
Is it ok to use some small but VERY strong Neodymium magnets screwed to the aluminum heat sink holding the spindle motor ? or will this affect the motor coils etc.
The machine is not really big enough for a dedicated dust boot.
Roy
01-11-2014 #2
I think that will be okay, it's a method used by many people. Velcro might be another idea if you don't fancy the magnets.
01-11-2014 #3
Thanks EddyCurrent
I have seen magnets used on frame below spindle but not on the heat sink next to the spindle
I will try it and report back here if I get a problem
01-11-2014 #4
Air is a very poor conductor of magnetic flux and aluminium is not much different, so very little will penetrate the short distance to the electrical steel inside the motor. The flux density in the outside of the stator (the 'back iron') is generally low, so increasing a it a little shouldn't increase the losses in the motor noticeably.
BUILD LOG: A sufficiently strong machine
By Jonathan in forum DIY Router Build LogsReplies: 42Last Post: 29-03-2014, 10:40 PM -
Zapp 3-Axis kit - putting it all together
By birchy in forum Motor Drivers & ControllersReplies: 5Last Post: 18-02-2013, 12:05 PM -
Making timing pulley - putting theory into action
By wiatroda in forum Metalwork Project ShowcaseReplies: 15Last Post: 28-11-2011, 02:22 AM -
Strong 1212ds - any advice greatly appreciated!
By MrWiz73 in forum General DiscussionReplies: 14Last Post: 30-03-2011, 05:17 PM -
NEW MEMBER: Strong 1212DS - any good?
By MrWiz73 in forum New Member IntroductionsReplies: 0Last Post: 29-03-2011, 11:13 AM
