    Hi Jazz, does that look ok, the t slot plate will be bolted directly to the adjustable steel frame. Then gutters can be added to the steel frame if im going to be running coolant or not, these will be just aluminium angle.
    Quote Originally Posted by Gotty101 View Post
    Yes but personally I'd have the rectangle cross pieces vertical so they provide more strength against deflection. Have a Flat base frame then sit Aluminium onto it then just make thin sheet surround which fastens into sides of ali plate.
    Thanks again Jazz, ill update it. I cant wait to start the build, especially when you look at the build logs on here.
    Trev
    Well small update, ive started building the top part of the CNC with alot of help from a close family friend.
    Here is a few pics of the progress.
    Starting work on the spindle brackets
    Main gantry uprights and bearing plates
    Gantry bearing blocks
    George and i on the Miller building the spindle plate.
    With regards to the steppers for the machine, would the 4nm or 3.1nm steppers be best? Im im thinking 4nm ones from cnc4you and am882 for the drivers. I wont get the drivers yet as i dont require them just yet.
    Trev
    Trev
    Looking nice so far, it's great when the action starts. I used those stepper motors and the AM882's, they work great but you might want to look at the updated drivers, the EM806; http://www.mycncuk.com/threads/8249-...5162#post65162
    I was disappointed to see the discussion about steppers - from the earlier pictures, I had hoped that this would be the first steam-powered CNC machine!
    Thanks EddyCurrent, ill have a good luck. The only reason for the drives is i know they are rated and they are available for a great price on ali express.
    Yes Neale, it could well be if George had his way. He has built loads of steam trucks, trains and a steam boat. He is such a cleaver guy and does all his designs in solidworks these days.
    Those parts are looking great. Well, yes, if the friend who's helping you has build those fancy steam engine things then I'm sure making the cnc machine parts are going to be like Gordon Ramsay whipping up a few snacks for a kids party :-)
    Plus one. G.
  1. Replies: 25
    Last Post: 30-08-2014, 08:33 PM
  2. Component Check
    Last Post: 22-04-2014, 06:04 PM
  3. Initial thoughts on new build
    By Neale in forum Gantry/Router Machines & Building
    Last Post: 25-01-2014, 11:05 PM
  4. Some initial questions....
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 27-01-2013, 03:00 PM
  5. Newbie Initial Wiring/Setup
    By Rikk in forum Motor Drivers & Controllers
    Last Post: 28-06-2011, 10:19 AM
